timk makes up for talent with an EFR
timk
Re: saboteur's NB
Postby timk » Tue Jan 24, 2012 8:07 am
Charlie has been through enough wheels to know a few well! :P
The offset is +25mm. We put some 8" +20mm wheels on BitRusty's track car and it was a fair bit of guard pulling, but I haven't touched the guards at all on this NB (not even rolled). Amazing how much difference 5mm offset makes. The tyres are 205/50R15 595RS-Rs.
I'll let you know after the 30th (Lakeside track day) if I need to roll them.
Thanks for the complements on wheel choice!
TieNN89
Re: saboteur's NB
Postby TieNN89 » Wed Feb 22, 2012 1:11 am
I hear the previous owner of this MX-5 is pretty awesome! :lol:
timk
Re: saboteur's NB
Postby timk » Sat Feb 25, 2012 10:23 pm
No rubbing at the track day, very impressed with the wheels!
I have since lowered the car a bit more than in that first pic, still no issues.
MX-5 Plus "tall boy" ROPS fitted.
Engine is a bit tired and is down on power, but a new build is now in the works! :mrgreen:
zero00
Re: saboteur's NB
Postby zero00 » Sat Feb 25, 2012 11:21 pm
Saboteur
Just fitted new wheels to my NB as well, got '949 Racing' 15 x 7.5 [matte black] with new KU36's on them - wasn't too sure about the 15 x 8 as mine sits pretty low!! The NA now has the 'King Zero' alloys that were on the NB fitted also with KU36's, the ride now in the NA is incredible!! I've done the roundabout thing thru my suburb and surrounds [at LEGAL speed!] and they feel great, and the ride is much softer than before even without touching the KYB AGX which are still set on '4'
I told JF at MX5 Plus i'd had it to 6000rpm and he said go harder! Wow, makes for fun entering the M1 at the Bribie Interchange!! :D
Roger D-SUNSHINE COAST
timk
Re: saboteur's NB
Postby timk » Sat Feb 25, 2012 11:35 pm
Good stuff Roger! Have you got a spare set of rims you can put some semis on? They make a world of difference.
timk
Re: saboteur's NB
Postby timk » Sat Jun 16, 2012 9:24 pm
Engine freshen up is well underway now:
TieNN89
Re: saboteur's NB
Postby TieNN89 » Sat Jun 16, 2012 9:58 pm
w00 h00!!!
corners
Vehicle: ND - Supercharged
Re: saboteur's NB
Postby corners » Mon Jun 18, 2012 4:44 pm
Any updates?
mrpham
Re: saboteur's NB
Postby mrpham » Mon Jun 18, 2012 9:37 pm
mmmmm fresh engine is fresh
Current Forum Specials!
timk
Re: saboteur's NB
Postby timk » Wed Jun 20, 2012 12:24 am
No engine updates yet, but it was a nice day so took a new pic of the car. I just replaced the first image in the thread with it. I only had my camera phone with me unfortunately.
Re: saboteur's NB
Postby Lokiel » Wed Jun 20, 2012 9:06 am
From that angle, it looks like you took it just before passing out drunk in the gutter :P
More proof that bronze rims on a green MX5 look awesome.
timk
Re: saboteur's NB
Postby timk » Wed Jun 20, 2012 9:29 pm
More engine progress!
Slugs, rods and crank in with ARP fasteners throughout:
Rotating assembly was balanced, you can see the holes drilled in the crank in the pic above.
zero00
Re: saboteur's NB
Postby zero00 » Wed Jun 20, 2012 10:05 pm
saboteur
You doing this yourself? If so, looking good!!
timk
Re: saboteur's NB
Postby timk » Wed Jun 20, 2012 10:12 pm
zero00 wrote:saboteur
Roger unfortunately I don't have the time to do this kind of work these days, Jason from MX-5 Plus is doing a great job however. Machining work and balancing has been carried out by Chilton Engineering.
timk
Re: saboteur's NB
Postby timk » Sat Jun 23, 2012 3:25 pm
The stock setup goes alright, however my engine is very tired hence the build.
Here is the clutch I will be running:
It is a modified Exedy built by Direct Clutch and is bolted to a Toda 1600 flywheel. Hopefully this combined with the 6 speed and 4.1 final ratio will be quite fun to drive!
Users browsing this forum: No registered users and 283 guests
