Andrew's '93 NA6 - KL V6 swap
lea
Re: Andrew's '93 NA6
Postby lea » Sun Aug 07, 2011 11:39 pm
Beelzeboss wrote:Thanks guys, I was really happy with the price.
What do you think of the new exhaust (basically just a rear muffler delete, totally reversible)? I think it's a bit too loud, lol.
Very nice, and loud, note you've got there... but your poor neighbors!! =)
Beelzeboss
Postby Beelzeboss » Fri Aug 12, 2011 9:45 am
Ah, they're pretty good neighbours :D. That was only taken at about 6pm. Since then I've added a pair of flanges to the exhaust so I can block it off. This pic shows what I mean:
With that aluminium plate between the flanges the exhaust is back to stock, and I think I'll leave it that way :NA6:
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
RedMX
Postby RedMX » Sat Aug 13, 2011 7:02 am
:shock: Sweet Jesus..... Hater's gonna hate.......
Nice thought on the exhaust system. just thinking that you could have got your exhaust shop to make a custom tailpipe with a sports muffler in a bolt-on/off configuration or something.
Not attacking you or anything.
Beelzeboss
Postby Beelzeboss » Sat Aug 13, 2011 11:15 am
:lol: The plan is for a whole new exhaust system from the head back so I wasn't really worried about ruining the stock system. I know it looks like arse but it was just a bit of fun. I was bored one afternoon and that's what I came up with. It really is too loud though, I don't think I'll unblock it again.
I could make a butterfly valve to go between the flanges and have a switch to open it from inside the car, but it's so loud I don't think I'll bother.
Andrew
NA-6 2.5 KL V6
Beelzeboss
Postby Beelzeboss » Thu Sep 01, 2011 8:39 pm
NB front brake upgrade :D
Old
New
The previous owner of the calipers painted them silver, which is good because they don't stand out under the standard wheels :D
The front rotors that I had were warped so I needed new ones anyway, and I thought a brake upgrade would be a good idea before chasing a bit more power.
Andrew
NA-6 2.5 KL V6
Beelzeboss
Postby Beelzeboss » Thu Sep 01, 2011 8:43 pm
I also bought an 8-ball and made a new gear knob. It feels much better than stock :) and the best part is it's a completely reversible mod :)
And my momo prototipo wheel which my uncle gave to me. He bought it new in the 70's :)
Andrew
NA-6 2.5 KL V6
BlackR
Postby BlackR » Thu Sep 01, 2011 9:56 pm
Beelzeboss wrote:And my momo prototipo wheel which my uncle gave to me. He bought it new in the 70's :)
I had a silver one like that that Dad bought in the 70's. He had the leather re done and gave it to me for my 19th. It was in my Type R when the car was stolen :(
Beelzeboss
Postby Beelzeboss » Mon Sep 12, 2011 7:15 pm
Aww that sucks, I really like the wheel. It suits the car and is a good size.
Over the last couple of days I made a simple log manifold to mount the TD04L turbo I have. I bought the turbo to use in my race car project but I'm going supercharger instead, so the turbo goes on the MX :lol:. I'm not aiming for big power, around 100rwkw would be perfect so this manifold should do the trick. If not, it only cost me $30 :)
Does anyone know what I'll have to do to get the car engineered in NSW? Any recommended engineers?
Also I'm not sure where to run the intercooler piping. I want to keep A/C and power steering. Any ideas?
Andrew
Andrew
NA-6 2.5 KL V6
Postby NitroDann » Mon Sep 12, 2011 7:32 pm
First manifold youve made? Butweld fittings from blackwoods?
Where did you get your head flange?
Did you stick weld it? Im getting my new welder this Week. :D
Beelzeboss
Postby Beelzeboss » Mon Sep 12, 2011 7:57 pm
Yes, pretty happy with how it turned out for a first attempt. I bought the bends from EDCON steel and I had a random piece of pipe in the garage for the rest of it.
Made it :) 8mm steel plate, drill press, angle grinder, files, lots of time. I also made the turbo flange. This is how I made the whole manifold for less than $30 8) I'm stuch a cheapskate. Tomorrow I'll get some bolts and some more steel to make the down pipe.
MIG welded, but I'm not very good at it yet. Probably would have done a better job with the stick welder :lol: Having a welder sure opens up a whole lot more stuff you can make for the car.
Andrew
NA-6 2.5 KL V6
Postby NitroDann » Mon Sep 12, 2011 8:19 pm
Awesome, Im going to make a heap of them in the coming months.
You havent tested it yet?
What did you use to make the exhaust ports oval, on the pipe I mean, Just in a vice until it was close? Or a better way?
Beelzeboss
Postby Beelzeboss » Mon Sep 12, 2011 9:13 pm
I just used a vice and got it pretty close. If I had a decent die grinder I could tidy up the pipes but they should be OK for the power I want. If I was going to mass produce them I'd try to make some sort of die to use in a press.
I haven't tested it yet. I still need to hook up the oil and water lines, fab the down pipe, intercooler piping and mounts, variable TPS, and wire in the Adaptronic ECU.
Andrew
Andrew
NA-6 2.5 KL V6
Postby NitroDann » Mon Sep 12, 2011 9:18 pm
I plan on making a vice mounted die.
What size buttweld fittings? 1.25'?
For oil feed, are you using the rear passenger side of the head?
Beelzeboss
Postby Beelzeboss » Mon Sep 12, 2011 9:35 pm
I think they were 1.25 or 30mm fittings.
I didn't know there was an oil feed on the rear passenger side of the head. Do you have a pic of where it is? Or can you describe it? I was going to use the one on the passenger side of the block near where the dipstick goes in.
Andrew
Andrew
NA-6 2.5 KL V6
Postby NitroDann » Mon Sep 12, 2011 9:40 pm
Its in the back of the head, passenger side, but its not really doable with the engine in.
Just use the regular one as you were saying.
