DRKKOS's NA6
RedMX
Re: DRKKOS's NA6
Postby RedMX » Fri Dec 23, 2011 1:19 pm
Looking sweet as usual :)
drkkos
Re: DRKKOS's NA6
Postby drkkos » Fri Jan 13, 2012 9:27 pm
little teaser.
Tyrepower North Melbourne
Craig M - Store Representative
PM/SMS for a quote | Tyres / Wheels / Alignment | 212 Abbotsford St, North Melbourne, Victoria
RedMX
Re: DRKKOS's NA6
Postby RedMX » Sat Jan 14, 2012 1:41 am
looks stunning in person too :)
drkkos
Re: DRKKOS's NA6
Postby drkkos » Fri Feb 03, 2012 8:57 pm
Ok, So all the work is done on the car for the moment except for some little goodies I've got coming in the mail to help with the look.
List of all the things I have done recently and will be doing!
Installed:
Enkei 92 15x8 +25 Black/Silver (Guards rolled also)
BC BR Coilovers 8kg/6kg
MX5 Mania Lower bracing Front and rear
K&N Panel Filter and Stock Air box with the front cut and the back plugged
4-2-1 Extractors (Heat-wrapped and Sprayed with high temp paint)
Redback Stainless Steel High Flow Racing Catalytic Converter
Genie Stainless Steel Cat Back Exhaust
GV Style Front Lip
Goodies coming are:
Clear repeaters and Side Reflectors
Polished Gear knob and hand brake handle
New Headlight lenses and housing
Phillips or Narva +100 H3/H4 Globes (For hills)
Things to do:
Transplant the sound system that was in my ute into the MX-5
Weld the Diff
Things still to buy:
DBA Rear Discs
Project MU D1 Pads
At GC With the front lip, Just got up the drive way without scrapping, just kissed on the way out.
Sitting pretty at the JDMST EOMM In Jan Under Bolte Bridge.
AUZJDM
Re: DRKKOS's NA6
Postby AUZJDM » Fri Feb 03, 2012 9:00 pm
Simple and clean, love it!!
drkkos
Re: DRKKOS's NA6
Postby drkkos » Thu Aug 30, 2012 12:14 am
Gonna revive this bad boy with a little teaser for everyone.
More to come.
Crooz
Re: DRKKOS's NA6
Postby Crooz » Thu Aug 30, 2012 9:23 pm
Love what you are doing with it man. Very jealous of your paint
koop21
Re: DRKKOS's NA6
Postby koop21 » Thu Aug 30, 2012 9:55 pm
nice itb setup, how did you do your vacuum?
mrpham
Re: DRKKOS's NA6
Postby mrpham » Fri Aug 31, 2012 10:37 pm
I think that manifold makes use of the Toyota vacuum system and fuel rail, I like it a lot. Saves money and space.
Current Forum Specials!
drkkos
Re: DRKKOS's NA6
Postby drkkos » Sat Sep 01, 2012 9:57 am
koop21 wrote:nice itb setup, how did you do your vacuum?
mrpham wrote:I think that manifold makes use of the Toyota vacuum system and fuel rail, I like it a lot. Saves money and space.
As John said, it uses the stock Toyota vacuum line (There are two links between 1-2 and 3-4), makes it alot neater and less hassles. From what I saw the other night they might have AE86 injectors in it, I have to make sure of this though.
Just waiting on the ECU to arrive then i will tune it during the week and I will order some cams with my next pay from work this coming week.
Also here is a picture of how it currently sits.
Re: DRKKOS's NA6
Postby Jeo » Sat Sep 01, 2012 11:31 am
That's really nice man. Well done.
Crooz
Re: DRKKOS's NA6
Postby Crooz » Sat Sep 01, 2012 3:41 pm
What tyres did you go with man? I have the Enkie Apache 2s in the same size
drkkos
Re: DRKKOS's NA6
Postby drkkos » Sat Sep 01, 2012 6:52 pm
Crooz wrote:What tyres did you go with man? I have the Enkie Apache 2s in the same size
Using my old RE001s that are 195/50R15, small amount of stretch but allows to be damn low with the camber pulled out all the way with no scrub
