Postby Magpie » Wed May 03, 2017 6:47 pm
Back on topic, after almost 99 pages...
A suggestion from a friend I made at WTAC last year (Lone Wolf Racing) was to make the base plate larger....
Well turns out it was a good suggestion, the load is better spread and when it is attached with some sikaflex it should provide a decent solution for the moment whilst I decide on the final wing choice... The boot moves more on its hinges than it does at the mount!
V2 and V1
ImageDSCN4240 by Eipeip, on Flickr
The plate now extends to the edge of the boot bracing. It may even be possible to put an eyelet in (through the support plate) and then add some wire supports. May even be possible to put a support from the boot up to the plate or even cut the slot in the supports and run the plate the entire width of the boot.
ImageDSCN4238 by Eipeip, on Flickr
Postby Magpie » Tue May 09, 2017 11:53 am
Will complete the fix today and re assemble.
Took the opportunity to test out another green... This is Kawasaki Lime Green. Need to contact Lokiel and get some pointers on how to colour the wing angle adjusters. Red would look fantastic with the green.
ManiacLachy
Engaged
Postby ManiacLachy » Tue May 09, 2017 11:57 am
Yay, pictures work now! I think you might claim the title "Patchy" from Stan soon.
Postby Magpie » Tue May 09, 2017 12:15 pm
No, almost decided the colour(s) that the shell will be painted. Waiting for the WTAC announcement before deciding the when. That is the new splitter and flared front guards, how will they be painted planned or current colours...
speed
Re: RE: Re: The Roadster NA Journey Begins
Postby speed » Tue May 09, 2017 6:51 pm
ManiacLachy wrote:Yay, pictures work now! I think you might claim the title "Patchy" from Stan soon.
Mazda.. Benetton edition :D
chefie
Postby chefie » Tue May 09, 2017 7:05 pm
Page 100
what a monster contribution
well done,green needs to be more Kermit the frog
98 NB8A Grace Green
LS 66.17,QR Club 69.27, QRSpr 63.58 SOLD
01 NB8B Grace Green
LS 64.66,QRNat 1.31.94,QR Club 65.17 QRSpr 62.36
93 NA8 Clubman
Postby Magpie » Tue May 09, 2017 8:50 pm
Attached the wing back onto the car. There is more movement in the boot itself than the mounts, just needs a test now.
Find out about WTAC tomorrow (sometime). Could be spending mother's day at Lakeside in the morning, subject to other half's approval (health). If we can get married at Lakeside having mothers day there is a non issue :)
ManiacLachy
Engaged
Postby ManiacLachy » Wed May 10, 2017 7:37 am
Depending on timing and various other factors I might see if I can drop by and say hello before running off for mother's day lunch.
Postby Magpie » Wed May 10, 2017 8:13 am
See you there, believe Shane will be there as well. Have to get the BAP's for club points :)
Wing back on, even in florescent light they are 'bright'. The edge of the plate can be seen and the distortion caused to the boot over the past 3 years is very evident.
The roof scoop (Kawasaki Candy Apple Green)
Many thanks to MX5 Car Parts for these shiny things... An old set of AD08R's are being put on today to test fit on the car :)
https://scontent-syd2-1.xx.fbcdn.net/v/ ... e=59B0D063
https://scontent-syd2-1.xx.fbcdn.net/v/ ... e=59B65613
Postby Magpie » Wed May 10, 2017 4:42 pm
Best email of 2017 was received at 1521 today...
CONGRATULATIONS - WTAC EOI ACCEPTED CLUBSPRINT
Postby Okibi » Wed May 10, 2017 10:36 pm
Awesome :mrgreen:
Daffy
Postby Daffy » Thu May 11, 2017 8:22 am
Well done mate!!! :BROADY: (P.S....those Advanti's are going to look great too!)
viewtopic.php?t=73496
Postby Magpie » Thu May 11, 2017 12:27 pm
Test fit up last night. I used my 2015 WTAC AD08R's as these will be replaced with the 2017 WTAC AD08R's. They are still suitable for a track day so may 'test' them on the QLD MX5 club track day for a session.
  1. The 205/50's look a little stretched however when you stack the tyres the rims do not contact each other.
  2. Had to cable tie the brake lines as they ran the risk of getting 'crushed'/pinched. Looked like the drivers side line brake line had already been a 'victim' to some previous rubbing. The brake line is not compromised and does not need to be replaced, just watched.
  3. No guard rolling required :) The car is still on stands so the wheel was jacked up to the point it started to lift the car and there was no touching, even at full lock. The front tyre temp sensors will need to be moved as they are very close to the tyre at full lock only.
  4. They are LIGHT 13kg each with tyres!
Photos were taken early this morning, will take it outside for a wash on Saturday so should get some better photos. Also took the opportunity to fully inspect the 6UL's and they are still in great condition (no craks).
ManiacLachy
Engaged
Postby ManiacLachy » Thu May 11, 2017 12:33 pm
What size are the wheels?
Postby Magpie » Thu May 11, 2017 12:36 pm
15 x 8 +25
Very light rims!
