Postby Magpie » Mon May 01, 2017 5:37 pm
Did one side today, not much shed time as I'm the domestic help at home at the moment :)
Slot cut, started with a dremel finished with my favourite too, the air body saw
ImageDSCN4227 by Eipeip, on Flickr
Made up a plate a little longer than the mount, same width. If this is not stiff enough I will use some stainless steel plate and extend it further into the boot and a bit of sikaflex. Dilling the holes into the plate, using another drill bit to keep it aligned works a treat.
ImageDSCN4228 by Eipeip, on Flickr
Attached the mount with temp bolts so can drill through the boot for the 2 extra bolts that will be used.
ImageDSCN4229 by Eipeip, on Flickr
ImageDSCN4230 by Eipeip, on Flickr
Drilled
ImageDSCN4232 by Eipeip, on Flickr
Mounted, need to purchase 8 x studs, put this is the final product.
ImageDSCN4234 by Eipeip, on Flickr
ImageDSCN4235 by Eipeip, on Flickr
Postby Lokiel » Mon May 01, 2017 6:19 pm
I haven't seen it done yet but wonder if a frame whose bottom is mounted to the floor of the boot and top sits flush against the bottom of the boot lid when closed that has bolt threads for the wing to be mounted to would work?
The wing could only be mounted when the boot lid was shut though.
Here's a side profile view of my vision in classic 1980's ASCII-art CAD form:
Code: Select all
        ===========  <-- Wing
       /B____B_/
========B====B==     <-- Boot Lid
      --B----B-
    /         |      <-- Frame in boot
   /B________B|
====B========B==     <-- Boot floor
where: B = Bolt and the car is facing left.
This solution provides solid mount points for the wing that wont flex (probably illegal for motorsport though since the wing needs to be removed to access the battery if it's in the boot - could make/add an external battery disconnect knob to get around this).
Postby Magpie » Mon May 01, 2017 6:25 pm
ASCII Art, BBS days and 4800 modems, aaah the 90's.
I'm thinking of a similar concept to this! The shell will become a test bed for a much stronger wing mount.
ImageDSCN3515 by Eipeip, on Flickr
MattR
Postby MattR » Mon May 01, 2017 6:30 pm
Just one comment Mark....
KISS
Don't overthink or overcomplicate it.....
Sent from my XT1635-02 using Tapatalk
Postby Magpie » Mon May 01, 2017 7:18 pm
Trust me the photo was purely to bring you out of hiding MattR :)
The photo is from one of the cars I shared a garage with at WTAC 2016. I do prefer Lokiel's version as it is what I'm planning.
speed
Postby speed » Mon May 01, 2017 7:30 pm
I like the photo version and thought you were doing a similar thing but more simple.
Lokiels version is a good idea though but i have no idea about the force applied to the bolts etc.
Interior frame would have to be perfectly flush.
MattR
Postby MattR » Mon May 01, 2017 7:32 pm
I'm back home later this week, so next week can dig out some examples of wing mounts used in earlier super taxis and some sports sedans.
Or just go all GT3 race car and swam mount the wing from the rear chassis
plohl
Postby plohl » Tue May 02, 2017 11:06 am
Magpie, there's already some good local prior art on wing mounts, that you've no doubt seen before, and possibly even forgotten about it.
http://www.aus-cartalk.com/forum/viewtopic.php?style=3&f=57&t=59941&start=105#p813283
zoomzoom wrote:...
I decided to make up some new wing stands for the extra downforce I am expecting. After a little consideration I opted to make them from steel tube, they work out to a similar weight to using alloy flat bar but are much stiffer and stronger and cost very little but time. I also chose to bring the wing up a touch, about 75mm or so which would bring the top up level with the top of the rood when at the highest AOA just in the case the local TimeAttack rules decide to go the way of the World TimeAttack.
The uprights
A bit of diagonal support
Wing mounted
plohl
Postby Magpie » Tue May 02, 2017 11:13 am
Never saw that, thanks!
MattR
Postby MattR » Tue May 02, 2017 12:02 pm
Here you go Mark.....
or
Postby Magpie » Tue May 02, 2017 12:33 pm
And where can I get it :)
MattR
Postby MattR » Tue May 02, 2017 12:55 pm
Gee, you want everything.....
With my limited access I was able to supply pretty pictures of swan mounts and mounting options and now you want to know where to get them from??????
Some people....... :roll: :roll: :roll:
And some more mounts to help......
Postby Magpie » Tue May 02, 2017 1:19 pm
Will have to relocate the surge tank now. Will just cut the bottom out of the boot as well so the surge tank can go in the middle...
Keep the suggestions coming MattR.
madjak
Postby madjak » Tue May 02, 2017 1:35 pm
Remove the camera and side wing mirrors and you've solved the issue.
I'm pretty sure mine moves around a bit but it's only a problem if you notice it or it falls off. Sure make it more rigid if you can but don't build some heavy scaffolding at the back end of the car... it will slow you down more than the wing.
Postby Magpie » Tue May 02, 2017 1:40 pm
I just wet myself laughing :)
