NitroDann's Long Awaited Garage Thread
Apu
Re: NitroDann's Long Awaited Garage Thread
Postby Apu » Wed Nov 26, 2014 11:38 am
I reckon it's just perspective...loooong manifold that pushes the turbo out, and looks really big cos it's near the camera.
Postby NitroDann » Wed Nov 26, 2014 12:22 pm
Postby Jeo » Wed Nov 26, 2014 2:20 pm
He lives! In forum form.
Postby Lokiel » Wed Nov 26, 2014 3:05 pm
Adding a support strut from the collector to the manifold flange?
noobee
Postby noobee » Wed Nov 26, 2014 4:08 pm
shouldn't they cam pulleys be other way round?
Mick
Postby NitroDann » Wed Nov 26, 2014 6:03 pm
It has a CNC alloy brace yes.
Sorry mick what did we do wrong :P
noobee
Postby noobee » Wed Nov 26, 2014 7:16 pm
probably nothing wrong if cas on the back,but aren't the steel pins in the cam pulley the triggers for engines with front cas,thats just what I assumed anyway.(just had another look at picture,realised cutaway tappet cover must mean no front cas,D'oh.its been a long day)
Mick
plohl
Postby plohl » Wed Nov 26, 2014 11:02 pm
what sort of alloy?
plohl
Nevyn72
Postby Nevyn72 » Thu Nov 27, 2014 4:03 am
plohl wrote:what sort of alloy?
Probably Indestructium with the size of that turbo! :shock:
What is this engine going to be fitted to?
Looks a little too wide to fit in the engine bay of an MX5...... :|
Postby NitroDann » Thu Nov 27, 2014 8:36 am
7075 brace.
Its going into an NA6.
speed
Postby speed » Thu Nov 27, 2014 9:00 am
Nice. Thanks for sharing!
I always enjoy looking at your pics :)
Postby NitroDann » Thu Nov 27, 2014 9:53 am
The car has had a bunch of changes.
If I havnt written all of this somewhere the engine was a late night Ebay purchase bought for <1000, this is literally a used super high comp IPRA engine that had throttle bodies on it, and we are going to absolutely jam it with boost.
it has:
CP pistons
Carillo rods
Knife edged and counterweight removed crank (super light crazy looking thing)
Maruha sump baffle
External oil pressure control
Extensive port work
Big valves
Double valve springs
Titanium retainers
Adjustable cam gears
Custom ground cams (mystery cams)
Its got 11.5: compression and I'm going to try and completely choke the turbo on it. IE: run ALLOFIT boost levels, on a dedicated E85 fuel system.
Its the first 11.5:1 turbo mx5 anywhere to my knowledge and its really just a "why the hell not" type of build.
We have upped the turbo size to a GT28RS, gone to a Turbosmart external gate, and it also have pretty extensive alloy ducting in the front end, Ill get photos of that up when its done.
I hope we can completely max the turbo at this compression and if we can we should make a healthy 400rwhp, and an ENORMOUS amount of torque with excellent driveability.
speed
Postby speed » Thu Nov 27, 2014 10:51 am
Pure awesomeness!!!
Postby Lokiel » Thu Nov 27, 2014 11:24 am
[quote="NitroDann"]
it has:
CP pistons
Carillo rods
Maruha sump baffle
Extensive port work
Big valves
Titanium retainers
/quote]
ABSOLUTE BARGAIN - the Carillo rods alone are worth $1,000!
You've basically got everything else for free given that those rods are practically indestructable.
Postby NitroDann » Thu Nov 27, 2014 12:24 pm
Yeah, so we figured.. ƒü¢k it lets do it.
No one else has had the balls, and even the local tuners ummed and ahh'd so we dropped it from 12.5 to 11.5:1 and we are ready to drop it into the car.
The inlet manifold will be a restriction we are sure, so eventually it will get a hand made one. :)
