Speed's boosted NA6
Daffy
Re: Speed's boosted NA6
Postby Daffy » Sat Jan 28, 2017 6:59 pm
That 1st real drive after such a long time off the road will be great Speed- looking good!
viewtopic.php?t=73496
speed
Re: RE: Re: Speed's boosted NA6
Postby speed » Sat Jan 28, 2017 7:10 pm
Daffy wrote:That 1st real drive after such a long time off the road will be great Speed- looking good!
Thanks Daffy. I can't wait!
jordan.k
Postby jordan.k » Sat Jan 28, 2017 8:01 pm
speed wrote:
jordan.k wrote:
maybe it was supplying too much oil causing the oil to blow out through the seals.
You were right. Drain pipe fitting was blocked!
Was the last thing I took off the t25 as I was switching parts across.
Any chance my T25 is still okay?
Im not a turbo expert, but I'd say it should be OK considering it was well lubricated with oil when it was running, good to see you found the problem quickly !!
NA6 Dulux spec
speed
Re: RE: Re: RE: Re: Speed's boosted NA6
Postby speed » Sat Jan 28, 2017 8:05 pm
jordan.k wrote:Im not a turbo expert, but I'd say it should be OK considering it was well lubricated with oil when it was running, good to see you found the problem quickly !!
Thanks mate.
Will see how the t28 goes and if it's too laggy I switch back the the t25.
Cus
Postby Cus » Sat Jan 28, 2017 11:06 pm
"my turbo might be broken, I'll put the bigger one on just in case" -- loving your work! :D
Looking good, on all fronts!
speed
Postby speed » Sun Jan 29, 2017 3:51 pm
Cus wrote:"my turbo might be broken, I'll put the bigger one on just in case" -- loving your work! :D
Haha, the bigger turbo was always a possibility.. I promise!
speed
Postby speed » Sun Jan 29, 2017 4:03 pm
Swapped some studs out from the other turbo, clocked the new turbo slightly as it wasn't lining up perfect with my IC piping.
Removed the turbo again (I've lost count how many times it's been off and on now), painted the trimmed rail flap to prevent rust.
I used this coz it says red on the can. Not the same red as the car but good enough for now since it's in a section you don't see.
Put it all back together.
Turbo still needs more clocking and one of the studs is about 2mm short!
When my new gaskets arrive I'll fix both of those issues.
Also ran my wide band under the stereo and the sensor feeds through the shifter hole.
Now stopping for a late lunch and a drink and later I'll recalibrate the wide band and refit the tombstone and centre console.
speed
Postby speed » Sun Jan 29, 2017 9:05 pm
Wideband calibrated, interior back together, stud issue fixed, thermo fan earthed until I can get a replacement loom side plug.
Running wise I just need to clock the turbo slightly.
Whats left to do before rego? Weld in the fittings after the air filter for BOV plumb back and catch can, refit the middle timing cover, fit my soft top and I'd also like to sort out a heat shield before I melt the paint off my bonnet.
Initial impression is that the turbo is not too laggy until it popped the cooler pipe off the turbo.
Daffy
Postby Daffy » Sun Jan 29, 2017 9:58 pm
speed wrote:Wideband calibrated, interior back together, stud issue fixed, thermo fan earthed until I can get a replacement loom side plug.
Ha!! I'm not the only one- happened to me about 4 times with the gt2871r- scared the s*** outa me the 1st time- gotta go hard core with them clamps mate :mrgreen:
speed
Postby speed » Sun Jan 29, 2017 11:07 pm
It's not the clamps, it's the fact that the turbo needs to be clocked more so that its online with the intercooler pipe. Then it will clamp better.
speed
Postby speed » Fri Feb 03, 2017 6:29 pm
Some more 'stuff' arrived ready for the weekend.
Daffy
Postby Daffy » Fri Feb 03, 2017 8:48 pm
speed wrote:Some more 'stuff' arrived ready for the weekend.
I need me a new one of them too!
speed
Postby speed » Fri Feb 03, 2017 9:26 pm
What happened to it and how long did it last?
Will fit the gaskets tomorrow and clock the turbo to match the IC piping. Once everything is back together I'll fit the beenie.
Daffy
Postby Daffy » Fri Feb 03, 2017 10:38 pm
speed wrote:What happened to it and how long did it last?
Its the turbo beanie I'll be needing, mine is starting to look a little ratty :?
I replaced one of the gaskets a while ago..... haven't got the details on hand of what (crappy) brand I had and what I had it replaced with, but this one lasted a whole 10,000ks :roll:
Hope the IC piping and clocking marry up without dramas mate :wink:
speed
Postby speed » Sat Feb 04, 2017 8:29 am
Thanks Daffy. I was asking about your beanie. How long did it last?
