Lightyear's SE Replica Track/Road MX-5
- beavis
- Vehicle: NB8B - Turbo
Re: Lightyear track car. Version ? Lost count...
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
Re: Lightyear's SE Replica Track/Road MX-5
Thanks for that.
- NitroDann
lightyear wrote:I can't believe that tiny little turbo can make the car go so well. If you don't have a turbo, your really missing out.
I just think why haven't I always had a turbo MX5. And people that have man sized turbo MX5's, man, they must be insane to drive.
Yep.
- davekmoore
How do you change the subject title?
- beavis
A forum Moderator can do it.
- lightyear
- Infinity & Beyond
I have repurposed the damaged spare bonnet. I figured the radiator will need all the help it can get. Marked some lines, made some cuts with the grinder, then bent up some alloy sides and riveted them in. And patched the hole from the naca duct.
image hosting 10mb limit
Given you have pretty decent sized holes in the bonnet, I always wondered if there was much merit in trying to create a duct in the tiny space between the radiator and the engine (without v mounting) to push most of the air up through the vent. Like the WRC cars.
Someone with your skills could make a sexy carbon fibre option.
- lightyear
- Infinity & Beyond
Will never work on this car. The radiator is pushed back 75mm. The radiator hose and bov and bits are all in the way. Would be nice. The c.f car will have something like that. Radiator will be in the boot space in that car for better ducting,
- lightyear
- Infinity & Beyond
- beavis
I hear the car is making an impressive 124.9kw and heaps of torque on the Dyno today.
- lightyear
- Infinity & Beyond
Give or take 60 kw's.
- bartmanftw
I think it needs more
- lightyear
- Infinity & Beyond
124.9 keeps me in restricted open. It could however be making more depending on dyno.
Will see if I can come up with some video. There was a number of 181 on the screen at one stage. But we didn't do a power rn at the end, and didn't get a dyno sheet.
- lightyear
- Infinity & Beyond
The car performed well today at Broadford, nothing broke. ��
I could not fix the oversteer problem. Needs a wing maybe. The brakes overheated, but In the following sessions I braked a bit earlier and they stayed consistently average for the day.
Needs a catch can, as the oil stays in the head a bit too long from G forces. All things I knew would happen. Except the oversteer, thought that wouldn't be as bad.
Ended up with fastest time outright on the day, and broke the club record by about 2 seconds. But sadly I won't get the record because I didn't hand in my Motorsport application to the MX5 club.
It doesn't feel as fast on the track. Could be the rich mixtures it has now after fitting a new fuel filter. The one that was on the car when dynoed was probably the original that has done 211,000km's.
Over 2.0 class results.
post images
post images
- 16bit
wow, a legit m3 csl hey?
i saw one of those on the road the other day.
