Tesco's NB8B
timk
Re: Tesco's NB8B
Postby timk » Thu May 29, 2014 9:14 pm
So was it just power steering fluid that leaked out?
M1474
Vehicle: ND - Turbo
Re: Tesco's NB8B
Postby M1474 » Thu May 29, 2014 10:52 pm
Just over two weeks to get her ready tesco, hope all goes smoothly.
GHETTOCET
Si.G
Re: Tesco's NB8B
Postby Si.G » Fri May 30, 2014 12:08 am
What is on your parts list other than steering rack and front sub frame? Rear sub frame?
Glad the motor is ok.
Si.
NA6 B6T
tescoking
Re: Tesco's NB8B
Postby tescoking » Fri May 30, 2014 2:18 am
The sump had cracked and the fluid was from there. Some part like the bar in the centre of the car got bended and I just let it be, not affecting anything anyway.
My 5
sailaholic
Re: Tesco's NB8B
Postby sailaholic » Fri May 30, 2014 7:22 am
The ppf?
tescoking
Re: Tesco's NB8B
Postby tescoking » Fri May 30, 2014 4:33 pm
sailaholic wrote:The ppf?
What is ppf?
My 5
kenson
Re: Tesco's NB8B
Postby kenson » Fri May 30, 2014 5:09 pm
Sad to hear what happened Tesco. Sounds like you have everything you need though.
PPF = Power plant frame. Long frame that mates the engine together with the diff.
You should be able to source one of those quite easily. Many years ago, MX5 Plus had a few lying around.
P.S. I'm out of motorsport for at least half a year. Work taking over :(
tescoking
Re: Tesco's NB8B
Postby tescoking » Fri May 30, 2014 6:13 pm
Do I have to replace my Power plant frame? I am not sure about that.
Where can you come back to the race with us? The next one will be 2 weeks later.
My 5
sailaholic
Re: Tesco's NB8B
Postby sailaholic » Fri May 30, 2014 6:18 pm
If it's bent it would be a good idea. It's keeps the gearbox and diff lined op properly. Ppf that is too short puts stress on the engine and gearbox mounts.
Re: Tesco's NB8B
Postby Regie » Fri May 30, 2014 8:28 pm
Looking at the above posts. You should take it to a mechanic that has an idea about mx5's if there is any in Perth.
This is the beginnings of another gearbox incident for you :shock:
Re: Tesco's NB8B
Postby KevGoat » Fri May 30, 2014 8:51 pm
A big +1 on what Regie said.
If the PPF is bent you will have big issues. Mine was only slightly out of tolerance and was causing me problems. Your mechanic should know about this.
It's fine to go to friends, but only up to a point.
Sent from my GT-P1000T using Tapatalk 2
Re: Tesco's NB8B
Postby Magpie » Fri May 30, 2014 9:26 pm
Gearbox take 2 begins now.....
Re: Tesco's NB8B
Postby Regie » Fri May 30, 2014 10:14 pm
Magpie wrote:Gearbox take 2 begins now.....
:shock: 8) :? :evil: :mrgreen: :oops: watch this space
tescoking
Re: Tesco's NB8B
Postby tescoking » Sat May 31, 2014 1:36 am
Can you guys show me a picture of the ppf that you are talking about please ?
My 5
Black_Penguin
Re: Tesco's NB8B
Postby Black_Penguin » Sat May 31, 2014 1:55 am
