Si.G's NA6
Si.G
Re: Si.G's NA6
Postby Si.G » Sat Jun 11, 2011 10:55 pm
Started work on the my cylinder head today. I have finished working on the upper and lower shoulders on the inlet side of all cylinders. I need to do some work in the chambers still, but I need the had gasket to do that.
I also have my new manifold, there is a bit of work to do to match the ports, as you can see below. The quality and fit of the manifold is very good.
As you can see from the pic above there is a bit of a ridge on the entry to the manifold, there is also a small lip in the runner (not visible) and of course the port needs matching.
Above is a finished runner, port matched and all, only another 3 to go. Obviously looks a bit rougher now, but it is certain blended better from the circular throttle body entry to the head port shape.
Si.
NA6 B6T
Re: Si.G's NA6
Postby NitroDann » Sat Jun 11, 2011 11:16 pm
We should hit a dyno together for shits and giggles.
You gonna run e85?
Also cant remember but this looks like a b6 head, right?
Si.G
Re: Si.G's NA6
Postby Si.G » Sun Jun 12, 2011 12:26 am
NitroDann wrote:We should hit a dyno together for shits and giggles.
You gonna run e85?
Not sure I can get e85 easily in perth, the head is a b6t, so I have some water plumbing to do.
NA6 B6T
Si.G
Re: Si.G's NA6
Postby Si.G » Sun Jun 12, 2011 5:06 pm
I have done 3 out of the 4 inlet ports now.
Also decided that the work I did yesterday needed more attention because it was not good enough, happy with it now though
Manifold is really nice quality, can't wait to use it.
NA6 B6T
Re: Si.G's NA6
Postby NitroDann » Sun Jun 12, 2011 5:10 pm
Nice work. Do you have access to a flow bench to see if you actually improved flow at the valve lifts you plan to use?
Si.G
Re: Si.G's NA6
Postby Si.G » Mon Aug 15, 2011 1:28 am
It's been a while - busy getting house reno phase 3 complete before my wife delivers our baby daughter in about 5 weeks time.
But I did manage to find some time on the car in between this weekend's club auto test, which was very wet and very fun!! Lots of sideways fun!
Quick aside - I really think some tyres you can purchase should be made illegal. I bought a new pair of Super Cats (made by bridgestone, I believe) for my 5, now I did get them because they are cheap since I rarely drive the car on street tyres (usually on r-comps). So driving to the auto test this morning (in the wet), I think if I had of sneezed on the freeway it would have put the car into a spin. I put on a bit of thottle on the slip road in a straight line and the back started stepping out. Anyone who was at the auto test will testify to the amazing lack of grip or traction these tyres have. So can you imagine someone who has never experienced over steer before driving on these tyres in the wet - simply dangerous. (step off the soap box)
So what have I done, well the bottom end of the engine is complete, had to wait for may gaskets to arrive from the UK, mazda wanted $75 for one of the sump seals, hence get a complete set of gaskets from the UK
Also the porting work on the head is all done, no pics of that, but pretty much more the same (See other pics) but on the exhaust side.
I preparation for the new engine, I have moved to Supra injectors (305cc) and I am currently wiring my coil packs
Next is head gasket, valve springs and retainers.
Si.
NA6 B6T
Si.G
Re: Si.G's NA6
Postby Si.G » Mon Aug 15, 2011 1:35 am
NitroDann wrote:Nice work. Do you have access to a flow bench to see if you actually improved flow at the valve lifts you plan to use?
Unfortunately I don't have access to a flow bench, it would be good, but I think a lot of what I have done is quite safe, just done the typical clean up, smoothed things out, particularly the lower shoulder and I did not have much choice on the head ports because of the manifold size. The ultimate flow bench will be dyno, when I find out if it has been worth it :)
Interestingly on the head I have the outer two cylinders are much smoother on the lower shoulders of the ports than the middle two, which have quite sharp edges in there, well did have.
NA6 B6T
Si.G
Re: Si.G's NA6
Postby Si.G » Sun Aug 21, 2011 4:57 pm
Got the car running successfully on the COPs today, so very happy with that. The rev counter has stopped working, but that seems to be common and is fixable with a capacitor, I think. I still need to make a plate to hold the COPs in place, so will post up some pics when I am done.
Si
NA6 B6T
Si.G
Re: Si.G's NA6
Postby Si.G » Sun Aug 21, 2011 11:02 pm
I did not think I would find the time today, but I have managed to get the COPs finished and here is the result.
So this completes the preparations for the engine. I did not want to be changing the injectors, fuel map, ignition AND engine all at the same time, just too many changes for effective fault tracking. So now, I hope I can focus on the new engine a bit more now. Want to get it done before November, because there is a time attack event I would like to enter.
Si.
NA6 B6T
Re: Si.G's NA6
Postby Okibi » Sun Aug 21, 2011 11:07 pm
Nice work Si :mrgreen:
deviant
Re: Si.G's NA6
Postby deviant » Mon Aug 22, 2011 10:59 am
Si.G wrote:Want to get it done before November, because there is a time attack event I would like to enter.
Si.
Which event is that? Is that the Australia wide series thingo that is coming to Barbagallo?
Si.G
Re: Si.G's NA6
Postby Si.G » Tue Aug 23, 2011 11:10 pm
Si.
http://trackbattle.com.au/trackbattle/
NA6 B6T
Si.G
Re: Si.G's NA6
Postby Si.G » Fri Sep 09, 2011 9:59 pm
I have ordered some stuff today - hoping to sneak in some engine building time while I am on paternity leave :D
Ordered..
-- solid Lifters
-- FM Valve springs and retainers
-- 0.040' +2mm overboard head gasket
-- New collets for the retainers
Any one know a good source for valve guides?
Also thinking that I might put the stock cams in to get the engine finished, running and set up before I move to some new ones - thoughts?
Si
NA6 B6T
Re: Si.G's NA6
Postby Okibi » Fri Sep 09, 2011 11:55 pm
What about that machine shop/engine builder in Osborne Park?
Si.G
Re: Si.G's NA6
Postby Si.G » Wed Sep 14, 2011 11:10 pm
Okibi wrote:What about that machine shop/engine builder in Osborne Park?
Funny you should mention that, been to see Mark at Harris Engines today to drop my head off. Mark is getting my valve guides, but more interestingly....
Bit of a school boy error on my part, I did not realise that I would need my valve seats cut for the new guides, but this got me thinking, so now I am moving to 1mm oversize valves on the intake and exhaust size :D
So that is about 6-7% increase in throat size on the both the inlet and outlet size, not sure what hp that will get me?
Si
NA6 B6T
