I fitted the soft top back on the car late today. all went well till I tried to clip and lock the roof into position. couldn't close it at all
above the rear window is a cross member for the frame with a 60 cm strap attached either end by 2 screws or 4 in total. at the end of this strap was a single hole
I decided to attach both to a protruding bolt from either side rain rail. no doubt this has caused the jam but when I removed the top I didn't see these 2 straps so really had no idea where they came from or what direct.
any thoughts appreciated and photo of the frame where the strap is attached either side. if you happen to have a photo roughly of the attachment area that would be very helpful
thanks
