danny
well the first paint handled two trips to the top end with 25,000 klm in total and 6 years on the car so it held well. I am actually using two plastic primers -one via aerosol and the more expensive stuff called lesonal 1k plastic primer which is sprayed directly on the plastic and pretty expensive at $55 litre
speed
if you keep this up -you will have to come up for a test drive
well its no-where near perfect BUT it is way ahead of the white car so I can say it has been worth the trouble
its only when you start adding stuff back on its starting to show its true colour
