NitroDann's Long Awaited Garage Thread
- 16bit
Re: NitroDann's Long Awaited Garage Thread
i tried to convince him of off the shelf stuff but no dice.
- NitroDann
tried to convince lokiel to not buy my manifolds !!!
Thems fightin' werdz
Here is some bits, the Forge actuator getting turned down in the lathe so it can be threaded further up the shaft to fit properly, I assume this actuator is designed for a slightly longer EFR turbo.. otherwise it would have been threaded further or had a shorter shaft.
And then a reroute pipe to go with the Begi spacer and modified front housing and a welsh plug to replace the front thermostat housing (pipe only pictured)
Upside down sorry
Upside down sorry
Dann, can you build me a reroute pipe since you've got a template now please?
- A.Chen89
- Vehicle: NB8B - Turbo
Apu wrote:Dann, can you build me a reroute pipe since you've got a template now please?
great minds think alike!
- NitroDann
Post un-instagramed picture of your bay and I will decide
You know what it looks like! We can move some of the oil cooler hoses.
- NitroDann
Yeh its the hoses.
16bit wrote:i tried to convince him of off the shelf stuff but no dice.
If I bought an off-the-shelf GT2650 kit, I knew that I'd always regret not getting the EFR6258 instead, it spools much faster and generates more power than the GT2560.
Now that it's almost complete, I'm glad I did, it's friggin' awesome!
Lokiel wrote:16bit wrote:i tried to convince him of off the shelf stuff but no dice.
Having spoken to you in person I can honestly say I think you will be disappointed about 2 months after you've got this back......
Because it still has stock bottom end and knowing you, you will want more! Haha :grin:
Not for long
Unfortunately until then, it will be like sleeping in the same bed as Salma Hayek but not being able to touch her until the engine is built.
Not for long
- bootz
- NitroDann
sailaholic wrote:Lokiel wrote:16bit wrote:i tried to convince him of off the shelf stuff but no dice.
It should do over 400 atw with a built bottom end if i did my job right.
He wont get bored of that haha
- NitroDann
Manifold is currently at the ceramic shop getting a couple of coats of Turbo X ceramic coat. Build to handle 2000c and keep the heat and therefore turbo spooling energy IN.
- NitroDann
Some bits and pieces.
Reproduction rear brace for Earlybird.
need a mania one to measure up from?Ken bought me a set for christmas but I only put the front on
Mick
Mick
