speed wrote: so I'm guessing it's the turbo seals.
Ah that sucks, what size oil feed are you using, maybe it was supplying too much oil causing the oil to blow out through the seals.
Love the build so far
jordan.k wrote:speed wrote: so I'm guessing it's the turbo seals.
Daffy wrote:Tight fit thats for sure! Progressing well though- what are you thinking RE heat issues from the turbo?
StanTheMan wrote:Bugger I was hoping you'd have it up & going
speed wrote:
Hold that thought.. hoping to start up with Wideband and t28 tomorrow
I'm hoping to harass the mx5 club of NSW at coffe & lies at pie in the sky next Sunday . Be awesome if you could make it.
Nevyn72 wrote:Providing there was oil in the turbo (given the smoke I would say that's a yes) such a short run probably didn't hurt it.
Depends whether the T25 is preferable to the T28 for some reason, if so then it's probably worth the time to swap them back and test.
You need to remove the T28 anyway to replace the lower studs for longer ones so.......
Users browsing this forum: Google [Bot] and 65 guests
