Bear's White NB8B Turbo "Snowie"
MINX
Re: Bear's White NB8B Turbo "Snowie"
Postby MINX » Tue Apr 07, 2015 10:07 pm
For the seat belts on the Sparco
On outside, undo bottom bolt, feed belt through hip belt slot and rebolt in, on tunnel side, install NA web style belt acceptor on the tunnel, pass through hip slot in seat
This lowers the belts correctly over your lap
Stuart
bear2230
Postby bear2230 » Thu Apr 09, 2015 9:57 am
MINX wrote:For the seat belts on the Sparco
Stuart
I will have a look into at that Stu
sailaholic
Postby sailaholic » Thu Apr 09, 2015 11:49 am
Outsides works, The inside trick didn't work for me. It left the buckle at an odd angle and digging into my hip.
bear2230
Postby bear2230 » Sat Apr 11, 2015 1:02 am
Gave up on the Sparcos. Its a 10 min swap over so I can live with that.
Engineer has now passed
(1) Ride height.
(2) Full brake test from 30km/h and 60km/h. This is for the blue slip.
(3) Heat shield (I made a beauty this afternoon. Admittedly this is Mk 3 but Mk 2 was pretty close. Mk1 was a disaster)
I have a small hydraulic leak somewhere and there was a little fluid in a few spots so I need to fix that by Monday and he wants me to make up a little bracket and hose clamp it to the bottom of the front shocks to secure the ABS line properly. Fair point, the MCA's have no bracket and the hose just dangles a little.
After he sees the secured lines on Monday night, he will pass it. :D :D :D :D :D
The car weighed in at a rather porky 1095 Kg with 1/2 a tank of E-Flex and the fruit and veg in the boot.
Standard is supposed to be 1050kg so the turbo, intercooler, oil cooler and all the associated piping including Dann's awesome 3" exhaust added about 50kg's.
bear2230
Postby bear2230 » Fri Apr 17, 2015 12:53 am
This photo represents the most significant thing to happen to the white car since getting it in December 2014.
NSW rego plates. Engineered, insured, registered and one very happy little piggy :D :D :D
A big thank you to all who helped me get it to this point.
Dave and Ajay at Mania,
Dann and Mat at Exocet.
Lou Iezzi (legend)
Colin Walsh at Ricol and of course Nathan Keogh for finally selling it to me and all the advice along the way.
Thank you lads. You guys Rock :beer: :beer:
Next on the list for this weekend.
(1) Braided hose on the heater hoses.
(2) Install the QFM A1RM front and back.
(3) Swap over my polished Manifold. (If it's a straight swap. I have 3 NB8A manifolds and they are all different)
(4) Drop the height by 10mm all round.
(5) Install the B/D bar.
(6) Harness eyebolts for the passenger side.
(7) BOV.
(8) Remove exhaust/turbo/dump and install Inconnel studs.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Fri Apr 17, 2015 9:27 am
Nice job Richard...but I really think you need a new project now....
Postby bruce » Fri Apr 17, 2015 9:34 am
Good stuff.
Weight is right, as all sources vary.
Did you get an Engineering Certificate and/or a sticker on the firewall?
bear2230
Postby bear2230 » Fri Apr 17, 2015 11:13 am
bruce wrote:Good stuff.
No Sticker.
I got a 4 page compliance certificate from the engineer.
They also print on your rego papers under "conditions and information" at the bottom.
Modified as per compliance cert 120xxxxxxxxxxxxx Issued 20150114
Best to keep that in the car just in case.
bear2230
Postby bear2230 » Fri Apr 17, 2015 11:39 am
Boyracer wrote:Nice job Richard...but I really think you need a new project now....
Lou, I told you, LS3 is what I want. My partner has a HSV Grange so will will burn that because it's a shitbox and I can have the engine....win win...
Postby bruce » Fri Apr 17, 2015 2:54 pm
Vic affix a sticker (new). One page certificate, which I've copied and laminated and keep in the car (just in case).
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sat Apr 18, 2015 9:05 am
Supercharged LS3 good enough for you??
https://www.facebook.com/flyinmiata/pho ... 31/?type=1
speed
Postby speed » Mon Apr 20, 2015 6:25 pm
Boyracer wrote:Supercharged LS3 good enough for you??
I'll take two if you're shouting ;)
bear2230
Postby bear2230 » Sun May 10, 2015 11:45 pm
I ended up removing the shinny cover as the coils were not all that secure and were causing some issues. It had a miss under load which turned out to be the rear coil breaking down. I ordered 2 new genuine coils from PEC Australia. I got them for $120.00 each. Mazda wanted $380.00 each.
http://www.ebay.com.au/itm/New-GENUINE- ... RK:MESE:IT
Managed to get my hands on one of these which was just what I wanted. Mounting holes for the coils but the best thing is that it says "Turbo" and yes, I am that superficial.
Then I removed the polished intake and put back on the ported intake. Ive lost all my bling in one weekend and Im thinking about selling the Carbing 3 point brace as well as its a real pain in the arse working on the car with it on. Its friggin in the way of everything.
bear2230
Postby bear2230 » Sun May 10, 2015 11:53 pm
So it was only going to me a matter of time before this started :oops: :oops:
Before:
If I ever found the guy who invented that sticky black gunk that holds the plastic down he is getting a punch in the head. Its the worse stuff in the world to remove. Took nearly an hour to get it all off and get it to this stage.
After:
Sound deadening doesn't take to long. 1 sheet 32" x 18" does this and a good bit of the outer skin. Now we had a decent sealed enclosure to work with.
Speaker install coming up. Nothing special just a pair of Alpine splits using factory wiring.
Postby Magpie » Mon May 11, 2015 8:23 am
There is a very long line to get to the black gunk inventor. Did you use a heat gun and then wipe it off?
