Crapweasel wrote:
100 posts Roadrunner!!![]()
Here's a theoretical top speed in each gear using 3.636 rear end like we have:
Awesome! And my prize is correct information on the internet! Thanks
Kev05 wrote:Is the car back on track? i.e problem fixed?
speed freak wrote:Looking good![]()
How good are the braided brake lines hey? I couldnt believe the difference it made when I got mine put on.
With the innovate oil temp/press gauge does it come with the 'normal' screw in type sesnors that would go into say a oil filter relocation kit port?
Also where abouts have you routed your wires for the gauges? I cant work out how to get them through the firewall and into the engine bay. Meaning I cant find a rubber grommet that leads to behind the dash somewhere.
tomli123001 wrote:Finally I fixed up the annoying kept coming off loose hardtop bolts with some threadlock. First time used it, I think I put a bit too much on the bolt here.
tomli123001 wrote:Finally, I did my suspension height to raising it, after Lockiel protesting this in my thread a number of times and reading the benefits of higher rear end. After all, I can now driver through Macca's speed bump now no problem at all.
raised rear height now. Looks very 4wd to some of you here, probably due to the angle of photo
tomli123001 wrote:The thread which the spring covers should never be changed, as this will reduce your travel.
