NitroDann's Long Awaited Garage Thread
Sean
Re: NitroDann's Long Awaited Garage Thread
Postby Sean » Sun Feb 24, 2013 5:47 pm
looks much better tidied up!
Dweezle
Postby Dweezle » Sun Feb 24, 2013 5:48 pm
Damn. So jealous.
That is perfect!!
Though i question the MX5 Mania name still on the car.
Seems a bit unfair to you.
Makes it look like they built that weapon!!
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby NitroDann » Sun Feb 24, 2013 5:56 pm
Yeah its way out of tune I know.
Dyno booked for friday.
Listen to my footsteps to get an idea how quiet it really is.
What a sleeper :oops: :mrgreen:
MrRevhead
Postby MrRevhead » Sun Feb 24, 2013 6:40 pm
Sounds quiet and free flowing from what I see/hear in that video. Also, I can hear the turbo starting to spool up!
Well done Dann!
Looking forward to some results (track or drag based)
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun Feb 24, 2013 7:46 pm
looks really nice, well done.
Postby NitroDann » Fri Mar 01, 2013 7:22 pm
New avatar :mrgreen:
16bit
Postby 16bit » Fri Mar 01, 2013 7:40 pm
very nice, what was the previous record?
Postby NitroDann » Fri Mar 01, 2013 7:42 pm
310, by a fully built 1.8L with a tubular manifold and 3" exhaust, worked head and a customer plenum and throttle body :)
Used to make 200whp at 4000, now it makes 300 at 5000 all the way to 8000.
16bit
Postby 16bit » Fri Mar 01, 2013 7:44 pm
wow, congrats. i assume you will post a graph in good time.
Postby NitroDann » Fri Mar 01, 2013 7:53 pm
Apparently I can go and get a printout in person with all the info next week.
The whole top flat part is over 300whp, did this run on 17x9 wheels and tyres also.
The intake everyone hated was 25 HP better than an open turbo, and 20hp better than bonnet up dyno fan on and no filter on an open 3" pipe.
mr bender
Postby mr bender » Fri Mar 01, 2013 8:44 pm
at what PSI Dann?
Postby NitroDann » Fri Mar 01, 2013 9:03 pm
Same as last time
ALLOFIT
22psi was everything it had, it was the T25 that could :P
mr bender
Postby mr bender » Fri Mar 01, 2013 9:13 pm
NitroDann wrote:Same as last time
ALLOFIT
22psi was everything it had, it was the little T25 that could :P
Fixed.
gslender
Postby gslender » Fri Mar 01, 2013 9:50 pm
....and Dann, what ecu was used, and did the tuner do the work or did you?
G
PaulF
Postby PaulF » Fri Mar 01, 2013 9:50 pm
It's a T25, the "little" is implicit in the name. :wink:
Congrats Dann. Will be good to see what it can do at Wakefield with the new aero as well as the new turbo setup.
