ManiacLachy
Engaged
Postby ManiacLachy » Mon Jun 06, 2016 8:21 am
Yeah, I'm not surprised practice was cancelled. It was bucketing down!
chefie
Postby chefie » Sat Jun 11, 2016 2:00 pm
For the passenger laps I handed the keys over to Jamie and he went for a few laps, hopefully he enjoyed them... Jamie has been very helpful in getting my times down.
Mark
First chance to thank you and follow up on the opportunity drive your fantastic car, the balance and acceleration is fantastic the acceleration and turn in is a credit to you in building and constantly developing your project along with improving your driving, I am sure you will be in 60's in now time and yes ill keep chasing
Thank you again for a great experience
98 NB8A Grace Green
LS 66.17,QR Club 69.27, QRSpr 63.58 SOLD
01 NB8B Grace Green
LS 64.66,QRNat 1.31.94,QR Club 65.17 QRSpr 62.36
93 NA8 Clubman
Postby Magpie » Sat Jun 11, 2016 7:21 pm
Glad you enjoyed the drive. Despite the imposed speed limit going through the dipper gave you an idea of how it handles and accelerates.
Postby Magpie » Sat Jun 18, 2016 5:06 pm
Spent the morning at QR doing General Practice, managed to find almost 4 secs off my previous time around the national, 1:27.80. Also caught up with Trackphotos :)
Only change to the car was taking a riser out of the rear wing. This was necessitated as the wing was only being held on by 2 bolts, 2 had fallen out! No spare bolts so used the ones from the riser. Can't say if the riser change caused the extra time, or the removing of the passenger seat or more seat time or the AD08's but I'm still happy:)
Looks like the front pads are stuffed so they need to be changed, played around with tyre pressures but apart from that no problems with the car. AD08's at 30 PSI hot are very 'squirmy'.
Also did a view looking at the RL wheel.
Postby Magpie » Sun Jun 19, 2016 11:41 am
Had a quick look at the log files as the fuel warning came on late in each session.
Session 1 - 14 laps (approx. 44 kms)
Started with 26.5 ended with 9.0. 40ltrs/100
at the last few corners (cool down) level fluctuated between 2.7 and 7 ltrs.
Session 2 - 14 laps (approx. 44kms). Was red flagged for about 10 mins so sat idling)
Started with 24.3 ended with 7.2. Used 17.1 ltrs for 44 kms or 39ltrs/100
All up used 100 ltrs for 5 sessions!
Postby Magpie » Mon Jun 20, 2016 11:03 am
Another sort of plus from the previous session, I'm working the brakes harder. Finally managed to get the temp strips on the front calipers to work. Have some larger brake ducts to install as well. Be interesting to see what the rear calipers have recorded. Plus, thinking of going to W6.5's on the rear as well as the front.
ImageIMG_1399[1] by Eipeip, on Flickr
Changing the front pads out on the weekend as well as putting in some spare rotors to see what temp they are getting up to. The T3's are almost worn out so need to decide on what rotor to swap to.
Also tested out my DIY rack for the track. A bit hard to steer when fully loaded so may have to swap out a set of wheels with casters, but then it will not travel over rough ground as well. Improvements planned are a battery box and possible a fold out bench on the side. Fits perfectly onto the Amarok as a bonus.
ImageIMG_1398[1] by Eipeip, on Flickr
Dan
Postby Dan » Mon Jun 20, 2016 12:51 pm
That's an awesome setup, looks really organised and professional.
Postby Magpie » Mon Jun 20, 2016 2:42 pm
Thanks Dan, it needs a few minor tweaks and is only really suitable for doing a weekend away as it cannot be put on off the car with everything already on it. So have to put it on the car pack around it then arrive at the destination get it on the ground and load it back up. However it saves lots of trips back and forth so is worth the pain.
Need a small crane on the Amarok to make loading easier, however not sure if the other half will indulge me for the crane :)
Trackphotos
Postby Trackphotos » Mon Jun 20, 2016 3:22 pm
I dunno, if it'll hurry you up I think she might not mind doesn't help when someone else is yammering at you and slowing you down, lol.
Sent from my E6653 using Tapatalk
Postby Magpie » Wed Jun 22, 2016 9:08 am
What have I learnt so far.... Less brake more corner speed.
This is from various times this year going through T2 at QR.
The IQQR 061816R1:10 is the most recent time. This lap was on AD08's whereas the other 2 laps were on FZ201's. It shows that I'm braking less and carrying more speed through the corner. Further the FZ201's did not have the same grip as the AD08's. However, it does show that previously I was braking TOO hard and washing off too much speed before the corner. The most recent (red) line shows that Imaintaned a constant speed through T2.
ImageT2_01 by Eipeip, on Flickr
At turn in, coming off the brakes and maintaining speed. This is what I have not been able to get right in the past. There is some throttle modulation to keep the car at speed through the corner, this could be improved. Previously it shows that I would have been accelerating into the apex, NOT good.
ImageT2_02 by Eipeip, on Flickr
Starting to wind off steering and accelerating out of the corner.
ImageT2_03 by Eipeip, on Flickr
ManiacLachy
Engaged
Postby ManiacLachy » Wed Jun 22, 2016 9:37 am
Maybe this guy can make sense of those graphs for me? :lol: (all I see is lots of squiggles, and my brain just says "nope!")
Postby Magpie » Wed Jun 22, 2016 10:00 am
Happy to explain... I'm getting faster :)
Postby bruce » Wed Jun 22, 2016 10:24 am
I like your trolley. If u could fit an electric motor to it...
StanTheMan
Postby StanTheMan » Wed Jun 22, 2016 10:27 am
bruce wrote:I like your trolley. If u could fit an electric motor to it...
LS1 conversion for the trolley. wouldn't that fly around the pits
Postby Magpie » Wed Jun 22, 2016 11:15 am
Electric motor to manoeuvre it around or something else...
