Hopefully you will rebound from the excitementCustardtart wrote:Quite excited today ......![]()
Okibi wrote:That joke was shocking, but I don't want to dampen your spirits
Magpie wrote:Okibi wrote:That joke was shocking, but I don't want to dampen your spirits
I'm sure you will rebound and bounce back.
Enjoy, is a fun course. I contemplated going but car will not be ready, however will be heading up the Landsborough to pick up my dampers and fitting them on Sunday. Yes I will have MCA suspension fitted...Custardtart wrote:Noosa Hillclimb
Regie wrote:did you loose coolant? if the reservoir tank is cracked it will be pretty noticeable around where the cap sits.
if the thermostat is stuffed it usually throws a code and will take ages to get to operating temp, have never heard of one that fails to open, they usually always fail to shut
Magpie wrote:Very hot in the South East of Queensland at the moment
Good thing about Noosa is the track is shaded most of the time, whilst this then gives hot/cold spot on the black stuff it is good for keeping cars a little cooler.
I trust the mechanic will find the cause and will make bump in on Friday.
