NA6 and custom ECU plans
StanTheMan
Re: NA6 and custom ECU plans
Postby StanTheMan » Thu Aug 10, 2017 5:12 pm
Youre not in over your head.
just head first. :lol: :lol: :lol: in my opinion is also the best way to learn.
I have to admit. I was also overwhelmed when I took the step.Information overload. It took me little to work out different sensors. The idle valve in particular. But you'll be fine
RobJ
Postby RobJ » Thu Aug 10, 2017 5:14 pm
When do you think a production run might follow, Noisy?
Im keen as mustard
noisymime
Postby noisymime » Thu Aug 10, 2017 6:09 pm
RobJ wrote:When do you think a production run might follow, Noisy?
Im keen as mustard
I have a couple left over from the Beta run if you're interested in one of those. Just shoot me a PM.
Otherwise, probably around 2 months after those with the beta units have had a chance to test.
RobJ
Postby RobJ » Thu Aug 10, 2017 8:49 pm
Pm sent.
Would it be helpful or step on your toes if I start a thread for the install and set up (it would be part 'how to' and part 'how do I?')
noisymime
Postby noisymime » Thu Aug 10, 2017 9:00 pm
RobJ wrote:Pm sent.
Would love to see it! I love watching people go through the install process all the way through to getting it running :D
Ross
Postby Ross » Thu Aug 10, 2017 10:49 pm
RobJ wrote:Pm sent.
Please do.
Ross
1990 BRG V-Special, NB Koni sport with King springs, MS-03's
Postby hks_kansei » Thu Aug 10, 2017 11:39 pm
When/if you do a plugin NB8A version I'd be tempted to have a go at fitting/testing one too.
I'm no tuner by any means, but would be a good choice if you want to see how a totally inexperienced guy goes with it.
(My tuning experience consists of single cyl carb fed small engines)
Postby 93_Clubman » Fri Aug 11, 2017 11:36 am
As a few forumites are looking at installing the Speeduino MX5 PnP, here's its very recently updated PDF manual, which may still be a work in progress: https://speeduino.com/Speeduino_mx5.pdf
Speeduino MX5 PnP web page looks like a work in progress compared to above PDF: https://speeduino.com/wiki/index.php/MX5_PNP
noisymime
Postby noisymime » Fri Aug 11, 2017 11:45 am
93_Clubman wrote:As a few forumites are looking at installing the Speeduino MX5 PnP, here's its very recently updated PDF manual, which may still be a work in progress: https://speeduino.com/Speeduino_mx5.pdf
The manual is very much a work in progress, but is mostly complete in terms of what should be needed for the PNP box. Some of the extra features aren't thoroughly documented yet, but if there's any details people need I can look at prioritising them.
(As its a wiki, new contributors are also always welcome!)
That PDF is generated automatically from the wiki, roughly once a week, so should be fairly up to date.
Postby 93_Clubman » Fri Aug 11, 2017 11:59 am
Didn't want to preempt anything, but posted the links as only found when Googling Speeduino & MX5, ie couldn't find links in the Speeduino wiki index, so hoped you wouldn't mind.
noisymime
Postby noisymime » Fri Aug 11, 2017 12:11 pm
93_Clubman wrote:Didn't want to preempt anything, but posted the links as only found when Googling Speeduino & MX5, ie couldn't find links in the Speeduino wiki index, so hoped you wouldn't mind.
Not at all! It was posted a few pages back in the thread, but these things are a pain to read back on so it's probably a good refresh.
Speeduino is very much a community focussed project, so the more people contributing and getting involved the better from my perspective :D
Ross
Postby Ross » Fri Aug 11, 2017 1:08 pm
LC-2 Wideband ordered :D
Next the VTPS, looking for the easiest plug n play version. VL type seems easiest.
Also need to start thinking about an intake an filter, since the AFM is going.
Ross
StanTheMan
Postby StanTheMan » Fri Aug 11, 2017 1:34 pm
it will give you good sound
Ross
Postby Ross » Fri Aug 11, 2017 1:56 pm
Thanks STM, was thinking along those lines, although probably keep the stock crossover.
Is that a Mania intake?
Ross
StanTheMan
Postby StanTheMan » Fri Aug 11, 2017 4:25 pm
yes it is It may also have been their first attempts at it. They eventually made one single pipe. Which is much nicer.
I originally had a steel pipe on a previous ECU for the AFM delete which was a perfect fit. Unsure of the actual size of it. I got tired of chasing aluminum, pipes as they are all either too big or too small.
went to bunnings.....$5 later.....
maybe we can ask Nitro Dann to come up with a solution for us that looks stunning & do a group buy.....
