Operation TLC
Re: Operation TLC
Postby Magpie » Wed Dec 10, 2014 9:30 pm
Danny I'm already spamming Dave's inbox :)
ED_MX5
Re: Operation TLC
Postby ED_MX5 » Wed Dec 10, 2014 9:37 pm
^ I got the same.
-PRAISE THE LOWERED-
Re: Operation TLC
Postby Okibi » Thu Dec 11, 2014 9:10 am
Try now, if you still can't connect Danny can you SMS me and i'll check it once i'm in at work.
Re: Operation TLC
Postby orx626 » Thu Dec 11, 2014 9:28 am
It's all good now Dave. :-)
MX-5 Plus
Vehicle: NC - Supercharged
Re: Operation TLC
Postby MX-5 Plus » Thu Dec 11, 2014 1:49 pm
Sunbaker wrote:Use K&N Juberide velocity stacks if using the car as a daily and the horns with Juberide mesh filter when at the track? As a solution.
Does the Piper Cross filter kit and back plate come with the kit or needs to be bought separately?
The Juberide mesh filter will do nothing to prevent fine particles entering the engine. These fine particles are the cause of bores and valve damage. Filtration is just as important at the track as it is on the street. All it takes is for the front running car to drop a wheel for you to ingest a large amount of debris.
The solution needs to be something that incorporates the trumpet, which without we may as well not run ITB's, but also provides suitable filtration. As these builds require aftermarket ECU's, changing setup does affect the tune, so again having the best of both worlds as 1 setup is the way to go.
The Piper cross filter kit is a seperate item.
These are really good discussion points for the new ITB thread.
MX-5 Plus Parts - parts@automotiveplus.com.au
MX-5 Plus Service - service@automotiveplus.com.au
Central 2A West, 605 Zillmere Road, Aspley, Qld, 4034 - Ph: (07) 3863 5858
http://www.automotiveplus.com.au
ndragun
Re: Operation TLC
Postby ndragun » Thu Dec 11, 2014 1:56 pm
That depends on who you order from. Sunbaker looks to be dealing with Rev9 - in which case the pipercross filter kit is included as an option when placing the order.
As I've since found out - you're probably better off NOT ticking that option, and instead buying the pipercross filter itself directly from Jenvey or someone else, and making a better backing plate yourself or getting MX-5 Plus to possibly make it. But its looking to be a sub-optimal filtration solution anyway...
1994 MX5 Clubman
XIDAs, Wilwoods, 6ULs
sailaholic
Re: Operation TLC
Postby sailaholic » Thu Dec 11, 2014 2:11 pm
Your also better off buying the Jenvy kit direct from Jenvy or from the Australian distributor competition systems last I checked the dollar.
mrpham
Re: Operation TLC
Postby mrpham » Thu Dec 11, 2014 9:22 pm
It won't let me view the ITB section :(
Current Forum Specials!
ndragun
Re: Operation TLC
Postby ndragun » Mon Dec 22, 2014 12:26 am
The slow progress continues... Had 4 wisdom teeth pulled last week so have been slowed with the huuuuuuurting and whatnot... Still managed to bolt up mr phams frame rails (http://mx5cartalk.com/forum/viewtopic.php?f=44&t=62457&start=105), progressed slowly on the re-wiring and cleaned up the interior. Originally, I'd intended to replace all the carpets in order to get rid of 20-odd years worth of beach volleyball sand (there was a LOT of that), dirt, grease, oil, farts and petrol fumes, but frankly the shipping on new molded carpet alone is around 3-600 bucks depending on where it comes from and really - the carpet itself is generally in pretty good shape anyway, albeit dirty and smelly.
SO - what we did was scrubbed the crap out of it with some "Fabra Cadabra" (yes, that's what it's called - get it from Supercheap) and a coarse brush, and then pressure washed it all and set it out in the sun to properly dry. And honestly - its come up absolutely magic. Aside from the right-heel spot I've worn through in the footwell, it looks absolutely brand new and is devoid of the greasey "MX5 smell".
Going this route though, its worth ripping off all the old "underfelt" since it won't survive the water treatment and (in my case) replacing it. I ordered an underfelt kit from MX5 Parts in the UK (while somewhat high on Codeine and laid up in bed...), and it arrived the following week. This new 'felt' actually resembles something of a stiff doormat and is about 10mm thick. Honestly I was expecting it to be a bit thicker and softer. Quite a bit harder than the original wooly, soft stuff that was in there. Having said that though - it does the job nicely and is cut pretty much spot on, once you figure out what goes where.
I again used spray contact adhesive to stick it all down, and its come up a treat;
And to hide the heel wear - I've chucked in some brand new 'factory' mats - which the car has never had;
http://www.mx5parts.co.uk/carpet-genuine-mazda-mk1-25-p-843.html
Now we move on to finishing up the engine bay wiring... and soon after that... with any luck... we'll start it up I guess!
1994 MX5 Clubman
ndragun
Re: Operation TLC
Postby ndragun » Tue Dec 23, 2014 1:39 am
Sunbaker wrote:Going back to your photo of the Jenvey linkage kit - cls1. How did you linked the two ball joints (Ref 8 on diagram) together? From the diagram, it does look like a part is provided with the kit. Also what injectors are you running, they don't look like stock from the pics.
You're right - the injectors are definitely not standard - they're uprated Bosch 225cc/min injectors... so I'll be using a bit of fuel at WOT if I'm lucky enough to get it running. You can also use these plus the standard injectors and do multi-stage injection if you're feeling tricky... but I ain't!
With the linkage kit - I'm not sure exactly what diagram you're referring to. Maybe the PDF here;
http://www.jenvey.co.uk/home/accessories/linkage/jenvey-dynamics/linkage-kit-single-cls1/assembly-instructions
If that's the case - you've a keen eye for detail. Its not marked up as an individual part in the diagram and frankly that's just a flaw in the diagram. You'll get it in the kit. Its just a threaded rod and a couple of nuts. They'd have to be trollin' not to give those three bits to you when you get everything else! :lol:
1994 MX5 Clubman
ndragun
Re: Operation TLC
Postby ndragun » Tue Dec 23, 2014 9:18 pm
Sunbaker wrote:Thanks.
Emailed them and they are sending a replacement.
Oh wow - so you have the kit and that bit was missing?? What a pain.
Glad you got it sorted though.
1994 MX5 Clubman
ndragun
Re: Operation TLC
Postby ndragun » Fri Dec 26, 2014 12:15 am
Sunbaker wrote:Also had a look at the supplied TPS today. Looks like it will not plug directly into the oem harness? Is there an adapter available or we'll be spicing.
I used a DT series Deutsch connector - just cut the plugs off the harness and the TPS respectively, and re-wired it.
Deutsch connectors are the absolute bomb. Super easy to wire up and pretty well bullet-proof unless you really, REALLY balls it up. They're worth their weight in gold, though depending on where you get them you might actually be charged as if they're made of solid gold. I got a kit off ebay virtually identical to this;
http://www.ebay.com.au/itm/DEUTSCH-249-PCS-CONNECTOR-KIT-DT-SERIES-INCLUDES-CRIMPING-TOOL-/221392089425?pt=AU_Car_Parts_Accessories&hash=item338bff3151
The same kit from Ashdown Ingram was a bit over $700 (but they could give it to me 'wholesale' for $500... pfft).
Now that the wiring in the engine bay and behind the dash is more or less complete, I'll try and get some daylight photos of what I've done and share... Generally I've aimed to hide as much of the wiring in the engine bay as possible without going too silly cutting and re-crimping, so most of it is either hidden up under the front guards, under the headlights or under the brake booster.
1994 MX5 Clubman
Re: Operation TLC
Postby Magpie » Fri Dec 26, 2014 8:28 am
An alternative are Weather pack connectors http://www.delphi.com/manufacturers/cv/connection-systems/weather-pack-connectors
It is easy to tell who wired what on my car Automotive plus uses deutsch and I use weather pack.
gslender
Re: Operation TLC
Postby gslender » Fri Dec 26, 2014 10:15 am
You can spend a lot of money on connectors. I'd be surprised how much difference exists but these from Jaycar are easy to get, inexpensive and don't require special tools.
http://www.jaycar.com.au/productView.as ... ATID=990#1
sailaholic
Re: Operation TLC
Postby sailaholic » Fri Dec 26, 2014 3:10 pm
Ive used that crap from jaycar.....they are as compareable to deutsch connectors as melamine laced baby foruma from china is to a mothers breast milk and no cheaper apart from not needing a a specialised crimiper.
I cut off the ones i used and swapped to deutsch DTM and still have un used one that i would prefer to thrown in the bin rathern then inflict pain on anyone.
