BAD NEW IS -
My car is not with me at the moment.
And it will not be for a little while.
GOOD NEWS IS -
It is currently being fitted with a Bolt In Half Cage courtesy of AGI PRECISION.
This bar is going to have to be 80mm above the top of the windscreen.
This will just allow me to be just 50mm under the top of the Main Hoop with a helmet on and in a Sparco Sprint V on stock rails.
It will be quite high.
But with no roof to worry about, i will be happy that i will have no CAMS issues and safety should be much increased.
The cage will also have shoulder protection by actually coming out past my shoulders.
This will make me soooo much more happier than having say a BD bar or MX5 Plus bar that just runs down almost in the middle of your back.
Not for everyone i know, but hey.
Hopefully this will be built and installed with the next week or so.
I really do not know how anyone is fitting what has to be close to 100mm under a BD BAR if you are average height.
The helmet is almost 50mm thick, and then the bar has to be 50mm clear of the main hoop.
I must be doing something wrong with how i sit
In other news,
I have removed the AIRCON completely from the car including the evaporator.
Many thanks to Chris Gough for helping me out with a replacement pipe duct thingy. (even if i did have to dig it out of your yesterdays seafood bin
Makes access to the whole hot side of the engine bay so much easier.
I also figured out why my radiator fan was not turning on.
Something had happened in the past clearly that made the fan separate from the motor and melt?
No idea what could have done this.
Anyways, got me a 2nd hand good one from a forum member for cheap. CHEERS!!
I now have cooling at traffic lights
Bought a bunch of tyres from OZZY TYRES when they had a deal on.
My brother and i bought between us,
4x Kumho KU31
8x Nitto NT555
We will run the NITTO's as a bit of a test.
http://www.nittotire.com/Tire/nt555They came to be only like $70 a tyre with the deal and the specs suggest they should be similar to an Adrenaline Re001.
We will get to test these out in a month at Wakefield.
Will post review.
Also still gathering bits and pieces for the rebuild.
Got hold of a Coolant Reroute from a forum member.
I believe it is MX5 Pluses system.
Looks the goods, though i now realise it appears to be a hotside pipe.
Really want to run coldside.
So will have to see if it is just as easy as reversing the Thermostat housing and maybe doing a bit of a mod to the piping.
Other than that, just really keen to see the cage being built and figuring out all the bits and pieces for the new BOLT IN HALF CAGE for NA/NB with glass roof from AGI.
