gslender wrote:1.9 .... So a 1.8 stroked?
G
BPs are well over 1.8L from the factory.
G
mazmad wrote:Interested to see how the itb's go, they are just a thing of beauty aren't they!!?? How did the venting go? I am going to try to get air into the footwell, that is the biggest heat buildup area. Not so pressing coming into winter but will get it done.
Edit. What does the coolbreeze scoop weigh do you think?
Magpie wrote:However the master cylinder maybe in the way (and have to be relocated) when the trumpet length and airbox dimensions are taken into account. Again there may have to be a compromise with respect to trumpet length.
koop21 wrote: Mags, to save you some time yes you will need to relocate the clutch master and the a/c if you still have it in there. I think i have same airbox as you do and gave up on that option because i didnt want to relocate that stuff. So i might explore this option in the future and cut up the box to make it fit around the the clutch master. Another option you might want to try is to offset the cuts outs ont the back plate for the trumpets so that left side (close the clutch master) just clears it. Just a thought.
mazmad wrote:I always have the roof on - keeps dust out, Wakefield in particular can be pretty dusty if people cut some corners or you have a cross country excursion. Have seen a number of options deciding which way to go at this point. Probably either go a quarter window with scoop ducted, or duct from original vent inlet.
How much difference did the wing make, do you have comparative times before/after?
mazmad wrote:Bit late to the party....great thread Magpie!
Magpie wrote:Side note is I checked my ride height at the pinch welds and found the following 65mm PF, 59mm DF, 59mm PR and 57mm DR so this may explain why the splitter is not giving a lot of downforce.
Magpie wrote:Not really an update by my son's red NA is now mine, he has gone for a 2012 model 4 door commodore (8,000k on the clock). So it is time to scale back the cars so the 800M looks like it is the first to go then I need to toss up between the Fiat X19 and the red MX5 NA6 plus the project boat in the shed needs to be gone (all on order of she who must be obeyed).
Magpie wrote:Well the last part for my ITB's has turned up after almost 7 months, the pipercross air box. Will post photos tomorrow. (
