tbro's 2nd NA, Scooter's resto
- rwf
- Vehicle: NB Roadster
looking great Terry
love it
love it
Retro 2nd NA, Scooter's resto
Sh*t, its been a while since I've done any updates on Scooter.
Our little trip down to E/C revealed a few concerns on long straights, mainly that our muffler was turning the boot into a bloody barbie on wheels
, seems that the restriction was just a might bit too much and so we ran with just a resonator and no tailpipe or muffler. Obviously not ideal but better than damaging an engine or worse, having a flaming Boags
So on my return to Brissy it was off to the muffler shop and a redesign of my own, going against what the MX5 experts say you must have and the outcome was a nice little increase in RWKW and a decrease in dbs, go figure eh!!!!
Boags has gone over to race with Ash Miller as my work was being a little bit "funny" and I needed to sit back and decide what I want to achieve with Scooter. I've decided to do the local races and maybe the Nats, as I've purchased a transporter to save me having to tow the car down and it worked out cheaper to have a motorised trailer
As my health hasn't been too good lately with the cold weather I can come and go as I need and won't be putting anybody else out.
So today I decided to finally fit the big cams I had rebuilt and nitrated, not a great job when you can't bend or your hands are all seized but where there's a will there's a way. Christopher Columbus that made a bloody big difference, the power band comes in at the same time 5200rpm but just belts you in the back and goes like a shower of sh*t, will dyno it again next week but i think I'm definitely over my hoped for figure from when I built the motor, only needed 3 rwhp to get that!!!!!
Fitted the wheels and RSR's from Boags and they have made it a lot better balanced car on the road. So all up not a bad days work, have gained hp and a bloody sore back ( anybody want some Arthritis FREE)
So off the Daybro for an early AM run tomorrow and see how it goes up the mountains
Oh yeah!! 13 weeks with out a bloody fag!!!!!!
Terry
Terry
- Boags
Re: tbro's 2nd NA, Scooter's resto
Can't wait to see the results from the dyno. :-)
Nice work mate.
Nice work mate.
- Steampunk
- SKYHI
Good to hear it's still progressing Terry.
You planning on doing the 1hr at Morgan Park?
Hey all,
Well took the car down and put it on the dyno and played with cam timing etc and pulled some good numbers and then the sh$t hit the fan electrically and we didn't end up finishing the tune. I was happy with the 127rwhp we started with (on a dyno not known for happy figures) and happier with the figures we were starting to pull by no matter what we did we couldn't retrieve the lost torque in the middle. So cams have come back out and in went a set of JUN 272s until the new bits arrive to up the compression ratio to around 12 to 1 and some more head work.
As I've been pretty crook from just after the dyno not much has happened. But one advantage to not being able to drive or work on the car has been I have the time to actually sit down ( me???) and read and investigate a few thing I've wanted to do for a while. I've ordered a set of new coil on plugs from the States and all the electrical fitting etc so when they turn up that will go on. I've fitted an Automatic throttle body and a new Variable TPS also sourced from the States. I ordered a IAT switch for a RX7 and have fitted and wired it up. I took the tranny out yesterday and will fit the Toda flywheel to see how much difference it makes before we redo the motor. Hopefully I'll have taken a few steps forward and maybe a couple back but that's what development is all about. I'm going to stick with the 1.6l motor as I don't know if I'll be able to race again and if not then it will still be a good road car!!!
I actually thought about selling both the truck (it's hopefully sold) and Scooter but had a thought hard about it and decided that I have spent too much time and effort into making him into a easy to drive and reliable toy to just sell him, and I figure that would be just giving up. If worse case scenario is I can no longer race I'm sure a certain person will take him out and play, until we can get Nick to have a go on the track
So over the next couple of months I'll keep playing and hopefully be ready for next year!!!
Terry
Terry
Hi all,
Well parts all turned up and I decided to try and fit them all up. Gearbox back in, what a sh8T of a job on your own, between throwing up and swearing I finally got the prick of a thing back in
The new coils turned up and then the plugs came a few days later. Sat down and had me a wonderful time making up a new harness, Then marked the rocker cover and fitted COPS retainers. All pretty like,
The red cover is for the road, the silver is for tuning on the dyno rather than taking it off to adjust cam gears
All fitted and running!!!
Wiring done and igniter gone.
I modified the air intake after testing it's efficiency at Amberley in some fancy test machine, seems the std L/S air box is ok for std motors, but was so restrictive at high rpm 7000rpm and higher it wasn't funny.
New adjustable TPS fitted and now needs to be wired up correctly to the Microtech and then resin fill the plug.
So I'm happy playing when I can ATM and hopefully it will be back on the road before too long.
So on Monday SWMBO is going to the P/O and picking up my pressy to me from the States ( hint!!!!12:1 and other bits to fit them to from PAECO)
Hey all,
Had a new clutch flex line made up to replace all that bloody stupid steel line and those annoying brackets. Its DOT approved ( not that it matters ) and will go straight from the master cylinder down to the slave cylinder.
As you can see the fitting into the master is a banjo fitting so I will need to file flat the surface fitting area so the cooper washers will seat.
fitted to the slave ready to fit to the car.
Probably not of a lot of use for a street car but certainly worth for a track beasty!!!
If you want one let me know
Terry
Terry
Hey all,
Well Scooters is now in the nude, yep all the stickers race no's etc have all been removed.
and now he looks like this,
So you ask is Scooter gunna race agian???
To be trueful I just don't know at the moment.
I'm going to remove the engine this week ( health permitting ) and WILL do all the mods that I was always going to do.
The car will be left nude until after i've done all the work and has been dynoed and I have the yeh or nay from the docs as to whether or not I can still race again.
If the answer is yeh, then Boags will have to organise some more sponsorship (hint! hint!) and we'll both go racing again. This also depends on how many meeting that will be avail in 2011 for prodsports in Qld.
If Nay, then Scooter will be finished off, suspension finished off, dynoed (to hopefully reach the 150 rwhp I've set for myself) and then will be offered for an EOI.
So not great Chrissy present but then there are a lot of people worse of than me.
Terry
Terry
- Guran
- Vehicle: ND - 1.5
Sorry to hear about your bad run of health, Terry. I hope you're on the improve.
- SKYHI
Hope you get some positive news soon Terry.
- Ollygt
I'm jealous of your knowledge, tech skill, garage, spare time and spare cash
Fantastic rebuild, I don't know the story behind the car but I kind of gleamed it from the posts and I'm sure the old owner would be very happy.
I'm trying to do a similar thing with my brother's old car which he gave to me for Christmas. The lil NA6 is in a poor state but a good base to bring back to it's former zippy self. (see it in the General chat under "Soon to be NA6 owner")
Oh dear, the wick in the engine's gone out.
Ollygt wrote:I'm jealous of your knowledge, tech skill, garage, spare time and spare cash
Hey all,
Couple of photos of the beasty now with his motor back in, rebuilt but unfortunately not to the extent it was going to be. The floods claimed everything at the engine shop and so we ended up doing only what was required rebore and a few other little tricks. The compression is now at 13.6 to 1 static so once tuned we should make some good HP. One thing I do know now is that the diff certainly works, scared the crap outa me through a roundabout, 1.6 don't do that in 3rd gear. Trying to decide if I'll paint the screen surround white or repaint the top red, bloody decisions decisions
Olleygt, mate, take your time, think before you act and try and find some of that magical stuff we all want (money) and before you know it you'll be where you want to be. It just takes time. If you need advise or encouragement this place has lots to offer and the Brissy blokes and girls are a good informative and helpful bunch.
Notice the additives in the piccy???
Terry
- Guran
- Vehicle: ND - 1.5
tbro wrote:By the way how close does your DB bar go towards the roof, mine seems to touch it??? Strange.
My BD rollbar touches the hardtop and soft-top. They've managed to rub off a bit of the powdercoat in the outer corners of the rollbar. It seems there is a bit of variability in the rollbar sizing or in the way they're fitted perhaps.
- rwf
I see some fun parts in that photo
These would make her no fit 2f again
Hope every thing going well for u mate
Is scooter coming out to qr in April for a play
Oh do you have any wheels and r888 for sale
Users browsing this forum: Google [Bot] and 4 guests
