The Red Green Machine
PaulF
Re: The Red Green Machine
Postby PaulF » Mon Mar 10, 2025 7:50 am
greenMachine wrote:He is hissed off, the engine has to go back to the bloke who built it, he didn't do the necessary machining for the new non-standard rear main bearing oil seal - could have been worse, the reason he rang was another engine he built using the same seal has just ruined a brand new, imported crank, for want of a little machining :shock: :cry:
So the engine builder called your neighbour and asked him to send it back because he'd realised his mistake? And presumably he's fixing it without charge. Honestly, in today's aftermarket that's a high level of service and integrity.
greenMachine
Postby greenMachine » Mon Mar 10, 2025 8:23 am
That's how I understand it. It is a small community, and word of mouth is probably pretty important. That engine is still untouched, never run, relatively simple job to rectify.
The broken one not so much, if the same offer applies - likely got metal shavings all through it, might/probably need a new crank, basically start the rebuild all over again. Costly for someone for sure!
:mrgreen:
greenMachine
Postby greenMachine » Mon Mar 17, 2025 1:07 pm
Said goodbye to the RGM this morning, waved goodbye as it drove off down the road ... :cry:
Next time I see it here it will be resplendent in its new paint job, hopefully in a couple of weeks or so. 8)
:mrgreen:
PaulF
Postby PaulF » Mon Mar 17, 2025 1:55 pm
Exciting times!
The American
Postby The American » Wed Mar 19, 2025 8:59 am
That’s a bit exciting. It’s amazing what fresh paint can do
ManiacLachy
Engaged
Postby ManiacLachy » Wed Mar 19, 2025 10:09 am
Fresh paint! You know your build is coming together when it's time for fresh pain!
Did you make sure to take a before photo for comparison?
greenMachine
Postby greenMachine » Wed Mar 19, 2025 8:24 pm
ManiacLachy wrote:Fresh paint! You know your build is coming together when it's time for fresh pain!
Pain?! PAIN :shock: :cry: :shock: Have you had a car/parts painted recently - it is going to cost me my first-born, unless someone tips him off and he goes into hiding. Really, it is a small sacrifice he should make for his old man, right?
I'm sure there is one somewhere. Better be, I'll need something to look at every 15mins to reassure myself it was all worthwhile ...
:mrgreen:
Users browsing this forum: Bing [Bot] and 5 guests
