My $10 Custom Dash Mat
Gladiator
Postby Gladiator » Wed Apr 03, 2013 4:25 pm
Since I recently replaced my cracked dash, I wanted to make sure this one doesn't crack. My cluster hood is wrapped in carbon-fibre, so i didn't want to cover that up, and all the dash mats you buy cover the hood. I was not going to pay $60 odd for one & then take to it with a stanley knife. I really dislike carpet style dash mats anyway. So I decided to make my own. Here's how I did it.
First i got hold of some strong clear plastic sheet to make a pattern. Since I still had my old dash I used that as it was out of the car, hence better access. I taped it to the dash and cut a rough pattern leaving a bit of overhang for trimming.
Now I have to make it exact, so I used my hot glue gun & with a blob every 150mm or so, held the pattern in place on the dash so I could trim it with a very sharp stanley knife.
Then it was off that sheila's shop (Spotlight) to get some Vinyl. I managed ti pick up a piece of textured black vinyl, 1350 x 400mm for $10. I was stoked. Once home, I laid the vinyl face side down on my bench then placed the pattern UPSIDE DOWN and smoothed it out & holding it still with tape. I traced the outline and vent holes with marking pen. These lines are NOT the cut lines. They are the fold lines. Then with the pattern still held in place by tape, I cut the shape about 20mm outside the pattern edge. This allows it to be folded over and glued or stitched. For the vent holes, I just made a single cut up the middle of the hole.
Now it's time to glue & fold all the edges. As there are very few straight lines on an MX5 dash, there was a lot of notches to be cut. It's not difficult, just tedious. I used a sharp stanley knife, as this gives a cleaner cut and is quicker.
I used the hot glue gun for all the edges as well. A flat piece of aluminium or stainless is good to use to press the surfaces together for a nice sharp edge.
Finally this is how the finished product looks. It's all held in place by some small bits of Velcro.
All up, $10 ( I already had the plastic sheet, glue gun, & Velcro) and about 3 hrs of my time.
If anyone wants the pattern, I'll put it in the post for you at my expense, on one condition..............you do the same for someone else when your finished, & post up pics your work.
MrRevhead
Re: My $10 Custom Dash Mat
Postby MrRevhead » Wed Apr 03, 2013 4:52 pm
Great effort!
I have contemplated doing the same myself after seeing Rev9 do something similar with leather on 'Sharka'.
I have acquired a spare black dash, I just need to SEM Colour Coat the relevant parts Tan to match my current interior (as acquiring a Tan dashboard was quiet a task).
Your offer for the template sounds tempting, although I'm not too sure when I will be able to get to doing the task. I will definitely keep it in mind though.
Well done!
Gladiator
Postby Gladiator » Wed Apr 03, 2013 4:55 pm
Thanks, I think I might go back to spotlight tomorrow to get more vinyl & redo my door trims.
Rolley
Postby Rolley » Wed Sep 24, 2014 5:47 pm
Gladiator do you still have that template laying around?
I would love to borrow it if you do!
I've spent the arvo trawling around the net for a cheaper dash mat and just found this post through google...
End result looks fantastic, I want to make one up out of carpet and use snap locks on the tonneau mounts to hold it in place. I'll wind up getting my mate who edged my floor mats to take his machine to it for me to neaten things up.
Gladiator
Postby Gladiator » Wed Sep 24, 2014 7:13 pm
I'm not sure mate. I'm at work on night shift but I'll have a look tomorrow arvo. If not you could always use my dash mat as a template.
Rolley
Postby Rolley » Thu Sep 25, 2014 12:47 pm
Cheers, that would be worth a beer or two for sure!
Gladiator
Postby Gladiator » Thu Sep 25, 2014 4:56 pm
Rolley, Ive sent you a PM
