niiko101 purchased a lot of Charlie91's parts when his MX5 was parted out. Be aware that the ECU probably has not been reprogramed from its previous engine.
Good luck and may your bank account be a bottomless pit!
Look at doing a NB8 motor swap instead of the NA8, the motor is better plus you already have an aftermarket ECU.
Gendy's NA6 MX5
- gslender
Re: Gendy's NA6 MX5
The NB8 head is recognised for being a better flowing design.
Sent from my iPad using Tapatalk HD
Re: Gendy's NA6 MX5
Better compression in the later engine also. And if you get vvt one then you get the main bearing support plate and bigger oil pump.
