Here's a sneak peek of the new inline 6 almost ready to be swapped into the NA6.
Should make a bit more torque than a B6.
hks_kansei wrote:Nah, will still have radiator etc.
Going to need to cut the rad support and shift the core forward a couple of inches, new core will be wider, but shorter to fit.
Then will cut a small bit from the firewall and widen the trans tunnel, so the engine will be set back a bit.
Should make it simpler to fit, and keep a bit more weight behind the axle line.
sailaholic wrote:Torque monster Rb 33
Users browsing this forum: ManiacLachy and 4 guests
