radio shows "ERR" after changing battery
Hellmun
Re: radio shows "ERR" after changing battery
Postby Hellmun » Sat Oct 26, 2013 12:57 am
Most likely it just needs the pin code input. Do you have the original car handbook? Usually the pin code is on a business card in that on most cars I've owned. Not entirely sure on the mx5.
This also belongs in the electrical forum.
Tezzax5
Postby Tezzax5 » Sat Oct 26, 2013 7:00 am
If it has the original radio then the pin will be the last four digits on the chassis number.
You only get three go's to type it in correctly.
Happy to flick you a pic from the manual if you don't have yours?
Cheers tez
Caffeine
Postby Caffeine » Thu Oct 31, 2013 4:48 pm
There is some sort of special button sequence that will unlock a locked radio. Had the dealer do it for me once after a service.
A bit like an MX5 konami code :D
Caffeine
Postby Caffeine » Thu Nov 14, 2013 9:12 am
Tried this?
When displaying "err":
press 6>>
press AM
press Auto M
press ^
- - - - is displayed
enter the code 1414
press and hold Auto M & 6>>
