Pete's track focused daily na6t in the making
peterwho
Vehicle: NA6 - Turbo
Re: Pete's track focused daily na6t in the making
Postby peterwho » Sun Jun 30, 2013 3:19 pm
Timmeh wrote:is it a smooth finish? where is this shop m,, looks the goods
I got my supplies from Whitworths marine & leisure, the finish depends on how good you are.
Apu
Postby Apu » Sun Jun 30, 2013 6:34 pm
Marine two-pak polyurethane?
peterwho
Petes Na6 going turbo
Postby peterwho » Thu Jul 18, 2013 10:34 pm
So much stuff has decided to arrive all at once, I plan to do the installs as efficiently as possible. The new 52mm radiator should be in by end of next week, ill then do the coolant re-route and add the Tridon High flow thermostat i got from Mania. And ill be using 80% Water, 20% Coolant and some water wetter.
Got my COP kit made by PureMx5 which is great if anyone is as bad as i am with electronics. Really neatly made and quality parts used. Installation took about 30 seconds!
At the moment im trying to remove as much weight as possible. Cutting the two teeth on the rear, and rear parts of the rear wheel well. Dash will come out soon and the frame will get trimmed. Also looking to cut out the web supports on the boot whilst still keeping the latch. Removed Hood latch and got some el cheapo hood pins, considering cutting out the hood webs too but just thinking if the popo pops the bonnet hes gonna set it all missing :S.
Oh and definately going to slightly gut the doors while trying to keep the power windows and door handles. Ive currently removed the soft top with the hardtop on. Carpets are gone only floor mats left, no radio, p/s or A/c.
Is there anywhere else i can lose weight from?
At the moment things are going at such a slow pace, the goal to finish by July 15th definately went out the window haha!
I haven't got much free time due to work but going to take a weekend off to get alot done! >=D
Here a pic of my gear all waiting to be put in! so much work, so little time
Apologies i know my details dont flow ha
PaulF
Postby PaulF » Fri Jul 19, 2013 1:35 am
And you're dailying this as well? HWP in your neighbourhood must be friendly.
peterwho
Postby peterwho » Fri Jul 19, 2013 1:42 am
PaulF wrote:And you're dailying this as well? HWP in your neighbourhood must be friendly.
Yeah i am :) thats why i have to make sure i finish stuff off before the next day comes so i can drive it LOL. whats hwp mean?
PaulF
Postby PaulF » Fri Jul 19, 2013 3:01 am
Highway Patrol.
peterwho
Postby peterwho » Fri Jul 19, 2013 4:53 am
Oh right, well i don't go nuts or anything on the streets, my car just looks like a bomb haha
peterwho
Postby peterwho » Fri Jul 26, 2013 2:34 pm
Just installed a re-route kit i bought from rxmx also known as Puremx5, and its great! I like the hard stainless lines over the rubber lines :D, Also installed a ASI 52mm radiator with dual fan shroud. And this weekend since ive got both days off ill be doing the head gasket, cam seals, cas o ring and valve cover seals! lets hope i dont destroy something
Users browsing this forum: Bing [Bot] and 9 guests
