First mx5
trader
Re: First mx5
Postby trader » Thu Mar 14, 2013 9:37 am
Wow! I can see some outrageous mods happening to this miata!
NB SE, NA 1.8.
ChrisFsoriano
Re: First mx5
Postby ChrisFsoriano » Thu Mar 14, 2013 11:37 am
Incredible POKE ! What is the offset ? they poke as much as my 15x10 +25 if not more ! if you live in QLD be prepared as the police are nazi's here when it comes to stance !
na8max
Re: First mx5
Postby na8max » Thu Mar 14, 2013 11:59 am
They are 15x9 et0. Once my suspension gets here I'll be dropping it as low as I can and then some negative camber should have it sitting just right. I ordered a guard roller yesterday, but the lip on the rear is pretty thick did you guys have any trouble rolling your guards
bazz1990
Re: First mx5
Postby bazz1990 » Thu Mar 14, 2013 12:34 pm
The rear guards are easy to roll ; )
Cant wait to see the 15x9 under the guards.
Good choice on the coilovers, i Love my stance coils
na8max
Re: First mx5
Postby na8max » Thu Mar 14, 2013 12:41 pm
Cheers baz, the coilovers are sure to arrive tomorrow but I fly back to sites tomorrow morning :x oh well when I get home I'm hoping the roller, coilovers and front lip will be here.
ChrisFsoriano
Re: First mx5
Postby ChrisFsoriano » Thu Mar 14, 2013 2:49 pm
Rears are easy, fronts won't bend too much. You will need a-lot of camber and run low as all ****. I'm about 80mm off the ground, with lowest point at 60 if not less, with natural camber I'm still not legal (poke wise). If The Cops ar'nt a worry for you then ill love to see how this turns out, it will be slammed !
Re: First mx5
Postby NitroDann » Thu Mar 14, 2013 2:56 pm
Hard Park 4 lyfe bruh.
na8max
Re: First mx5
Postby na8max » Thu Mar 14, 2013 9:59 pm
So my suspension arrived today and being impatient I couldn't wait till my guard roller arrived so I fitted my suspension today. I need to roll the guards and then I will go a bit lower. I've got maximum camber at the moment but once I roll the guards I'll back off the camber for a little more poke. Image
