Since I put this on wassup's garage thread I'd better leave him alone and obsess on the M2 1028 here.
Since there's one for sale right now in Japan.
Anyone want a cheap and extremely rare M2 1028?
Modded as a race car - PLEASE PM! Hopefully it comes here!
Since it's set up already as a circuit racer, with hardcore porn race engine mods, it's worth a look!
It would be pretty hot to have a rare M2 1028 as your race car.
A genuine M2 1028 in white (translated link).
http://www.importmonster.com.au/view?ur ... jpg&title=Anyone interested in the car?
Note that this auction car's look is
a bit wrecked since the owner sold off the Vitaloni/M2 1028 mirrors! wtf?
itbs!...or 'H6 year M 21,028 roadster 4 connected throttle'.
I've not seen a white NA M2 1028 ID tag before, have you?
The translation's terrible but it seems to be heavily modded to be a circuit racer, with lots of internal engine mods as well as the Rx& FC3S 4 pot calipers and bigger rotors. Hence the wheel change.
Quite a package, so enjoy the read.
You might be better able to translate than me.
M2-1028.
...4 connected you exchange to the throttles, control the computer, with the F [kon] V professional of HKS.
...the owner when overhauling... piston for race/lace... EX high cam of HKS... inserts the strengthening bubble spring ... piston and the connecting rod the weight adjusting...crankshaft we have heard that the balance [do] [ri]...lightweight flywheel and the strengthening clutch.
Furthermore, rammer foot [sutenresumahura], you exchange the catalyst to [metaritsutokiyataraiza], take official recognition. Because the piston of big bore size for race/lace was inserted...displacement has risen, but as this has taken official recognition, there is statement in car verification. ...the oil cooler of the radiator and one type has been attached in order to make management optimum. Furthermore, the core is the aluminum make of bulk. ...brake, 4 pod ... FC3S on the front ... large diameter rotor, the large diameter rotor is installed even on the rear.
Also [burekibaransa] is installed. Front and back adjustment type we install also LSD in the stabilizer.
Suzuka it ran also the circuit and the TI circuit, but it could enjoy rather.
Presently C ring type height adjustment suspension of [orinzu] has been attached, but pyro of the upper mount the rice increases exchange. In present specification, it depends on also the tire, but or the high-speed circuit it is quick the straw, the way you were moved.
...owner full has overhauled travel distance, in addition because I overhauling the head after only the 2000 am running in 2007, you think that it is from now on. Because the front owner one time has exchanged also the body, it is thought as the thing which is not problem even in body rigidity and the like. However because, the body changing is done, because we have become authority carving, restoration history makes unclear. If car it can have verifying with verification, you understand, but it is genuine M2. Big the scar, there is no dent. Because genuine having tried to re-cover, removing, we keep the seat, we transfer together the occasion where it transfers the car. Large amount the commodity, inside thing and the engine whose remodelling place is many we request present car verification concerning the information from the front owner.
