Qracing and Dashware software review
Links to your favourite Multimedia happenings to do with the MX5/Miata
Postby Magpie » Sun Jul 22, 2012 11:40 pm
Equipment: Contour Plus and Qstarz LT-Q6000 http://www.qstarz.com/Products/GPS%20Products/LT-Q6000-F.html
Software: Qracing http://www.qstarz.com/Products/Software%20Products/QRacing-F.htm and Dashware http://www.dashware.net/
Qracing
Qracing software comes with the Qstarz and is mainly for the reviewing of data and setting tracks/splits etc that can be exported back to the recorder (not the purpose of this review) and it feels like the video part is just a bonus feature. Whilst it is capable of having up to 9 videos linked to the recorded data I found it very tedious to sync just one and would slash my wrists if I had to do 9! It may have just been me or something that I was doing.
However once you have synced the video you can watch the video at the same time as the GPS recorded data but it can not be exported as a standalone video.
Dashware
I used the same data as for Qracing. First I had to export the Qstarz GPS data, then import this into Dashware. Then the video file selected (not sure how many can be used). Syncing was very easy as you can adjust both the video and the position independent of the other and on the same screen (not like Qracing). Once the data and video is synced the gauges are put on the screen and then you trim and export the video. It took me about 15 mins to produce the video below.
One thing I did find out is that the gauges are linked to a GPS data and if you remove that GPS file the gauges do not function and you need to delete and place new ones. Not that you will be deleting the GPS data all the time.
The Contour does come with its own software for very very basic videos and it does use the GPS data provided you upload it to Countour’s site. However, when you export (from Storyteller) to You Tube it does not include the GPS data. I may try and use the GPS data (from the Contour Plus) and compare it to the Qstarz’s and see if the info (speed/position etc) is any different.
All in all the Dashware is a cheap and very simple programme to use and makes a nice end product that looks good, however the Qracing software allows you to analysis your driving a lot better. Further, it allows you to configure a track and splits and upload it back to the recorder for use next time as well as export the GPS points to Google Earth (however it is not accurate as there appears to be a slight difference in the projection being used). Also in Qracing you can compare laps (up to 3) and see where you are in relation to the other laps, it was interesting to put my first ever run against my best and see the change in lines and speeds (again this is not the reason for this review).
Conclusion?
I guess Dashware is geared towards showing people what you have done and Qracing is for you to understand what you have done.
Video
Kev05
Re: Qracing and Dashware software review
Postby Kev05 » Mon Jul 23, 2012 7:44 am
Magpie, I like to the track location display and the gear change LED in the dash. I would have to find out more at the Aug 5 gathering. Thanks.
gslender
Postby gslender » Mon Jul 23, 2012 8:24 am
I'm going to using this software in about 12 hours after I collect some video and combine some telemetry from a GPS and engine mgmt system.
http://www.racerender.com/RR2/Features.html
I'll report back here once I do.
G
Postby Magpie » Mon Jul 23, 2012 9:39 am
Kev05 - the LED in the dash is a shift light (it comes on at 5,000 and flashes at 7,000)
gslender - should we ask the mods to create a sticky for video software reviews and keep it all in one thread as my title would not allow people to find your software review? It will be good to see yours with engine data as well.
rossint
Postby rossint » Mon Jul 23, 2012 10:35 am
This is done with the free version of Racerender.
http://www.youtube.com/watch?v=K8ZQ9GOAKtU&feature=plcp
It's not as good as Dashware I don't think, Racerender seemed to interpret the data a bit differently than Dashware and takes a bit more work to get everything sync'd up. They both work but they're both pretty clunky pieces of software, someone needs to do a nice Mac version.
gslender
Postby gslender » Mon Jul 23, 2012 5:18 pm
Magpie wrote:gslender - should we ask the mods to create a sticky for video software reviews and keep it all in one thread as my title would not allow people to find your software review? It will be good to see yours with engine data as well.
Good idea. Why don't you PM one of the mods and ask them to change the title and make sticky!
G
Return to “MX5 Multimedia”
