Drift Miata from Italy
Links to your favourite Multimedia happenings to do with the MX5/Miata
hot rod
Postby hot rod » Tue Dec 22, 2009 5:36 pm
Postby bruce » Tue Dec 22, 2009 5:46 pm
I wonder how the intercooler gets any air?
Postby Jeo » Tue Dec 22, 2009 5:56 pm
The radiator is angled back quite sharply to create a forward facing v shape out of itself and the intercooler. Provided you have somewhere for the air to go after the intercooler (giant bonnet vent typically), it works quite well as they both get cold air rather than the radiator just getting the alrready warmed air off the intercooler in a traditional front mount setup. There are a few good threads on cr.net about V-mount setups.
Or was that a comment as to where the air is meant to go after the intercooler, for which I have no answer.
CapitalF
Postby CapitalF » Tue Dec 22, 2009 6:11 pm
bruce wrote:I wonder how the intercooler gets any air?
Good question re air exit - even though he appears to have a bonnet vent top of bonnet, our passenger side.
The other MX5 I've seen with this runs more ducting and a Garage Vary bonnet - See http://www.triplezoom.com/gallery/gallery2.php?mode=album&album=/02%20Features%20Gallery/Chris%20Lee=1995%20Miata%20R#
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
philz
Wheel guru
Postby philz » Tue Dec 22, 2009 6:19 pm
It still gets air, the setup is v mounted.
Tthe postives, both the radiator and intercooler will receive air equally, shorter intercooler pipes= better response, the air that the radiator gets will be cool instead of hot, ie/ air goes past intercooler than radiator
It's more commonly seen in rx7s, which have cooling problems.
Probably the only con, is that it takes up much more space.
Postby Hammer » Tue Dec 22, 2009 6:24 pm
Hmmmm. I love the bonnet.
Postby Jeo » Tue Dec 22, 2009 6:54 pm
:shock: Oh how I love tht Chris Lee one
wazman
Postby wazman » Tue Jan 05, 2010 1:51 pm
Nice car.
Brightly colored wheels seems to be "IN" at the moment.
Its running D2 suspension !!!! be a shame when they snap in half and the car hits the wall :cry:
ilovedrift.com
Return to “MX5 Multimedia”
