Turbo vs supercharged mx5 on Mighty Car Mods!
Links to your favourite Multimedia happenings to do with the MX5/Miata
speed
Re: RE: Re: Turbo vs supercharged mx5 on Mighty Car Mods!
Postby speed » Tue Nov 01, 2016 5:33 pm
mk wrote:Supercharged is better then nothing
It's in the middle off turbo and na
My na6 is the first supercharged car I've owned
I've had a few turbo cars
The mx5 is very nice to drive supercharged and I like it
It's made a fun car into a car that can go fast
I'm glad you are enjoying my old bolt on kit. 130kw is nothing to sneeze at for the small outlay and I quite enjoyed the linear power band and retaining the stock driveline minus the clutch.
I also liked the fact that I didn't have to change the extractors.
When tuboing a na6 the cost jumps up significantly when you need to replace the entire drive train, brakes and exhaust manifold.
Guess it all depends how serious you need it to be but that MP45 doubled the stock output on a budget.
trader
Postby trader » Tue Nov 01, 2016 6:04 pm
I also drive a NA8 (supposedly 98kw). fun factor zilch compared to the rotrexed 1.6...
NB SE, NA 1.8.
Postby Okibi » Tue Nov 01, 2016 7:37 pm
I remember TimK saying his supercharged NB was very thirsty as a daily driver. A turbo car, i'd assume you plod around off boost more, I know my car drinks like a pig when on boost.
Postby bruce » Tue Nov 01, 2016 7:41 pm
We all knew the results before they started. The pros/cons of each are well known.
It's just entertainment for the un-informed.
siege
Postby siege » Tue Nov 21, 2017 2:00 am
Love MCM but felt the missing elephant from the room was a roots blower alternative.
Part of the reason the rotrex looked weak next to the turbo setup was that it took so many revs to produce a meaningful boost pressure, so wouldn't it be interesting to also compare a roots blower with a small pulley that makes more boost at a low rpm?
I made this comment on the video and they replied that they would like to do the comparison at some point but it wasn't possible this time. I guess they weren't successful in reaching out to any of the manufacturers.
2000 NB8A in Racing Green / Carbon fibre cowl intake / Racing beat muffler
Postby NitroDann » Tue Nov 21, 2017 9:35 am
There are no competitive options.
speed
Postby speed » Tue Nov 21, 2017 2:31 pm
^ what he said and I've had both.
bootz
Postby bootz » Tue Nov 21, 2017 4:13 pm
I have been looking for 10 years for Sprintex WA to do a kit for the mx-5. Sadly not everyone is geographically close to Nitrodann. So this is only available for the Honda Jazz. :roll:
EASE OF INSTALL
• Completely bolt-on
• Self-contained oiling – no need for external oil lines
• Fully integrated supercharger system
• Estimated installation time of 3-4 hours
PERFORMANCE & RELIABILITY*
• 67% more horsepower; 102 HP stock to 171 HP supercharged
• 47% more torque; 88 ft/lb stock to 130 ft/lb supercharged
• *Performance results may vary based on vehicle condition, modifications, etc.
OEM STANDARD & STYLE
• Engineered and tested to OEM specifications
• Uses stock air filter housing
• Completely reversible
siege
Postby siege » Tue Nov 21, 2017 8:51 pm
That would be pretty cool. And it's twin screw so more efficient than a roots system?
Postby NitroDann » Wed Nov 22, 2017 8:15 am
It's a 67% increase as compared to 150% increase (Our kit).
150/60 =2.5
Our kit is 9500 drive in drive out.
9500/2.5=3800.
So unless it's 3800 or less installed and tuned, its poor value.
That's my opinion.
siege
Postby siege » Thu Nov 23, 2017 7:53 am
To be fair, it's 67% increase in power on a 1.5L Honda jazz. We don't know what that twin screw blower would make on a 1.8L mx5 with a big pulley to make a boost level more comparable to your turbo.
The FFS is claimed to make 300hp with a big pulley, injectors and e85.
The MCM turbo was clearly kneecapped in the comparison as many people point out, I just think it would be more interesting to see a supercharged application making say 12 or 14psi like the turbo can, then compare those.
ManiacLachy
Engaged
Postby ManiacLachy » Thu Nov 23, 2017 9:04 am
The comparisons have been done, and done, and done again. If you want power, or even just power/$ then turbo is the answer.
If you're willing to compromise power for whatever else floats your boat, such as the ability to revert back to stock at your whim, then you can convince yourself to go super.
But don't kid yourself about the comparison, the MX-5/Miata has been around for 28 years, every possible FI combination and modification has been attempted. The turbo is the king.
Postby NitroDann » Thu Nov 23, 2017 9:08 am
siege wrote:To be fair, it's 67% increase in power on a 1.5L Honda jazz. We don't know what that twin screw blower would make on a 1.8L mx5 with a big pulley to make a boost level more comparable to your turbo.
There isnt an off the shelf option CAPABLE of comparable results.
siege wrote:The FFS is claimed to make 300hp with a big pulley, injectors and e85.
Tom who owns FFS is a serial liar and will say anything at all to make a sale. He participated here around 3 years ago and he lasted like 2 days because he was called out on his lies. Whenever he lies he just says, "I have engineers to figure that stuff out I really dont know everything about it, im just trying to explain what they explained to me". 110% absolute lies.
siege wrote:The MCM turbo was clearly kneecapped in the comparison as many people point out, I just think it would be more interesting to see a supercharged application making say 12 or 14psi like the turbo can, then compare those.
You already sawe them both at 10psi in the video, both at 12 or 14 psi wont do the blower any favours. The turbo on the MCM video was running lower boost than we run on our drive in drive out packages. Our base kit turbo is capable of over 25psi. We have cars making way way over 350 rear wheel horsepower with it.
Postby NitroDann » Thu Nov 23, 2017 9:12 am
100% Lachlan
The problem with blowers is that they arent particularly efficient. You need a big one with a big pulley to increase power significantly and that requires a lot of intercooling and also takes a lot of power from the crank to run it(meaning to get high RWHP figures you need even higher boost again, much higher than an equivalent turbo).
If you have access to a serious and exotic fuel, like methanol/C16/Nitromethane you can use a huge blower, fit a tiny pulley and the fuel will do the rest of the work for you. If you are using a street fuel then the fuel is regularly the limiting factor and the efficiency of a turbocharger plays 3x as nice with a turbo as it does a blower.
For a big family sedan with a v8 a blower is a great way to gain 25%, because the engine feels the exact same, but 25% stronger. But when you start with 100hp like in an mx5 you need 200% + to really get the car moving, and thats not possible with a blower on pump fuel without a lot of the things people feel are compromises on a turbo (long charge pipes and intercooler, standalone ecu etc).
By the time you have a good powerful blower setup built and supported you have compromised a lot of what people like about blowers and should have just had a whole extra 50-100rwhp and got a turbo.
Return to “MX5 Multimedia”
