Turbo vs supercharged mx5 on Mighty Car Mods!
Links to your favourite Multimedia happenings to do with the MX5/Miata
Tigger
Re: Turbo vs supercharged mx5 on Mighty Car Mods!
Postby Tigger » Thu Oct 20, 2016 11:32 am
Code4
Postby Code4 » Thu Oct 20, 2016 7:29 pm
Nothing really surprising I thought. Good vid.
Would like to see the same amount of development time spent on supercharger kits as has been spent on turbos in the past.
Looking forward to episode 4.
Guess its whatever 'blows your hair back' works for the non-racing user.
Never put the top up unless the storm has a name.
StanTheMan
Postby StanTheMan » Fri Oct 21, 2016 4:24 am
Reading stuff from around here I got the impression lag is a thing of the past.
Will be interesting to hear thier feedback on how they drive.
speed
Postby speed » Fri Oct 21, 2016 8:06 am
I expected a bit more power from the Rotrex. The guy that bought my MP45 kit made 128kw.
Maybe the Rotrex has greater efficiency rather than power?
Also thought that a ball bearing turbo reduced lag significantly but I've never had one.
All of my turbo cars have been stock size or just one size up to reduce lag and provide quick spool up in a usable Rev range for street driving.
In the vid they were talking about the area under 2800 rpm were the turbo wasn't on full boost. I suspect that at 2000 RPM the turbo is boosting but just not the full amount.
Don't think I ever drive under 2000 RPM so to me I'd say there is no lag.
Am I correct applying this logic or is it not as simple as that?
StanTheMan
Postby StanTheMan » Fri Oct 21, 2016 8:25 am
right
I guess it all depends on set up and your driving habits . I was cruising around 2000 rpm but that was with aggressive street cams & heaps of advance. No way I could have done that on stock cams. Timing advance was changed just before I pulled the head off recently.
In the old days I used to barely get below 3000 rpm with just the basic mods on Patchy.I Used to rev the crap out of it in Peak hr traffic.But I didn't do a lot of peak hr commuting in those days.Ive never owned a forced car. Guess I'm getting older
billybunter
Postby billybunter » Fri Oct 21, 2016 4:53 pm
Lag! what's this lag they keep talking about! :lol: must only be on the standard 180 rwhp tunes and an option on bigger numbers :roll: looks like I missed out again :roll: :lol:
smy0003
Postby smy0003 » Fri Oct 21, 2016 6:00 pm
I must've also opted out of this lag business as well.
The only reason I see for superchargers is to achieve a specific exhaust note. Which is a completely valid reason, just not a performance related one.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
StanTheMan
Postby StanTheMan » Sat Oct 22, 2016 8:30 am
You blokes should be ashamed of yourselves. Bypassing lag. What would the die hards think?
rascal
Postby rascal » Sat Oct 22, 2016 9:18 am
smy0003 wrote:The only reason I see for superchargers is to achieve a specific exhaust note. Which is a completely valid reason, just not a performance related one.
or to keep your gearbox in one piece.... The linear nature of the power delivery is much more friendly to boxes..
ManiacLachy
Engaged
Postby ManiacLachy » Sat Oct 22, 2016 11:16 am
It seems like they really handicapped the turbo to keep the fight some what fair. Though I guess they could have done more to make the SC more effective too.
It's an interesting comparison, but I would have liked them to have had a full on go with each setup. And take them to Dann for the tuning :mrgreen:
Postby bruce » Sat Oct 22, 2016 11:29 am
Engine longetivity. They are turboing a non-turbo engine.
Sailor
Postby Sailor » Sat Oct 22, 2016 12:34 pm
I haven't yet seen a supercharger setup with a small pulley to give lowdown boost and a blowoff valve to bleed off the excess at higher RPM.
I like the nice linear pull of my SC NC but admire the work Nitro Dan and others have put into reducing the lag in newer turbo installs.
Rob
Sailor
Postby Sailor » Sat Oct 22, 2016 12:36 pm
bruce wrote:Engine longetivity. They are turboing a non-turbo engine.
Engine longevity...Any increase in power.
Make more power and use it..the engine will wear faster..that's life!
Rob
trickytrev
Vehicle: NC - Supercharged
Postby trickytrev » Sat Oct 22, 2016 7:44 pm
Rob couldn't agree more not even mine needs a blow off valve take the power plough it through the engine love a good blower
Blown 300+
Wivvix
Postby Wivvix » Fri Oct 28, 2016 9:31 pm
Part 4 is up. I'm looking forward to the segment where they actually drive these on some twisties or a proper track - skid pan is okay but doesn't really tell the full story either.
Return to “MX5 Multimedia”
