ECU Terminal Crimp Tool Recommendation
Roadrunner
coyotes after you
Postby Roadrunner » Tue Oct 05, 2021 8:47 pm
What tool do you use for crimping ECU terminals on an NB loom?
I’ve been using a Delphi crimper that’s amazing for open barrel crimps (I’ll never solder again!). It crimps the 040 III Multilock terminals solidly but the crimp ends up being slightly too wide (pancaked) to fit in the socket. The crimp needs to be almost a square shape.
I googled 040 crimper and TE Connectivity sell one but at $800 I think I’ll pass :lol:
Been searching and came across a crimper from Jaycar that has changeable dies and “looks” the right shape but not sure.
https://www.jaycar.com.au/quick-change- ... p/p/TH2006
Is there a standard “go to” crimper for ecu terminals?
MeepMeep
greenMachine
Re: ECU Terminal Crimp Tool Recommendation
Postby greenMachine » Tue Oct 05, 2021 9:31 pm
There's a video on the Haltech site, might help ... video, or this one ... another video specifically on crimping. That's as good as I can do!
I did find this page of crimping tools too. 8) :D
:mrgreen:
bartmanftw
Postby bartmanftw » Tue Oct 05, 2021 9:37 pm
I also use the Delphi tool as well as a Utilix 147A for open barrel splices. The Utilix tool can crimp slightly smaller barrels as well as rounded ones. Pretty sure I used it when crimping the TE multilock terminals for the ECU.
https://www.engineeringsupplies.com.au/product/147a
I've also got a generic ratcheting one that can have different dies fitted. Can't remember where I got that from. Might be similar to the Jaycar one but your link is broken.
Roadrunner
coyotes after you
Postby Roadrunner » Wed Oct 06, 2021 2:24 pm
Sorry this is the correct link (I always forget to put it in the URL tags)
https://www.jaycar.com.au/quick-change-crimp-tool-dies-26-18-awg-non-insulated-crimp/p/TH2006
It looks square edged as opposed to V shaped. Just not sure if it’s small enough.
This is the tool I use at the moment and you can see the teeth are quite V shaped to accept the open barrel crimps.
https://au.mouser.com/ProductDetail/Aptiv-formerly-Delphi/12085271?qs=xyz6lfZ1ktJSpPwnGuiR8Q%3D%3D
MeepMeep
Postby Lokiel » Thu Oct 07, 2021 9:26 am
This is the one I use with all my electronics:
https://www.amazon.com.au/Engineer-PAD-13-Open-Barrel-Crimper/dp/B00IWD9XKU
You can find them cheaper if you shop around - this link has lots of info on it.
I bought mine several years ago with the additional head and it cost a whopping A$300 back then.
You won't need a square-forming crimp tool, just one that crimps to a circular size that fits within the receptor.
bartmanftw
Postby bartmanftw » Thu Oct 07, 2021 5:46 pm
That one looks pretty neat Lokiel. Is it spring loaded as well? I'm tempted to buy it.
Postby Lokiel » Fri Oct 08, 2021 9:44 pm
There's a wire spring on the rear if that's what you mean.
I bought these after soviet from MT.net recommended them. If you've seen some of his wiring work/braiding, you'll know that he knows his stuff.
bartmanftw
Postby bartmanftw » Sat Oct 09, 2021 12:24 pm
Yeah that's what I mean. The ones I've got have worked well for me but when crimping a lot of terminals my hands start to fatigue from having to constantly open them up again awkwardly with one hand after crimping.
I ended up finding a kit that was only slightly more expensive that buying the tool and the dies separately but it comes with a nice case :D
Postby Lokiel » Sat Oct 09, 2021 7:03 pm
Pictures or "it didn't happen"!
(I really just want to see what you got)
bartmanftw
Postby bartmanftw » Sat Oct 09, 2021 7:17 pm
Roadrunner
coyotes after you
Postby Roadrunner » Fri Jan 07, 2022 12:45 pm
I ended up purchasing the Engineer PAD-13 from Rhino Tools in Sydney. First crimp in confirmed it was worth the money. Light yet very solid build.
I was a bit worried as I'm used to using ratcheting crimps and using the ratchet to hold the terminal while I line up the wire, but this held the terminal easily in place. I'd still use the Delphi tool for open barrel crimping as you kinda need 3 hands for that to make sure all wires on both sides are fully in, but as a terminal crimper I highly receommend the PAD13.
Thanks for the advice :beer:
MeepMeep
Postby Lokiel » Sat Jan 08, 2022 3:53 pm
Crimping Tip
I make factory-looking crimps using the tool I referred to earlier with this technique (I'm right handed):
1. Cut a pin from the roll but leave the break-off tab still on it (you might want to weaken it first by bending it back and forth a few times)
2. Strip the wire to the length needed
3. Use your left index finger-tip and thumb-tip to hold the pin and wire in place (pin's crimp tabs facing thumb)
Leaving the pin's break-off tab in place makes it MUCH easier to hold against the sheathed wire while making 2x crimps since you can easily hold the wire against it and make BOTH crimps.
4. Crimp the un-sheathed portion of the wire first since this prevents the pin from from bending-length-wise which happens if you do the sheathed portion first (crimp tool's "m" side facing finger)
5. Crimp the sheathed portion second (usually you'll need to use the next-largest crimp-tool slot to do this)
6. Break off the crimp's tab by bending it back and forth.
Some of you may be able to get away with removing the crimp's break-off tab right from the start but I find that too fiddly to hold everything in place while crimping.
Notes:
* DON'T add solder, it'll make the wires brittle
* Sometimes the end crimp-tabs on the pins are too long and you have to shorten them to prevent the crimp from bending incorrectly, instead of folding inward neatly on the wire's sheath. I just cut them down with side-cutters.
* Sometimes you need to "pre-squish" the tab's on the pins because they're too splayed to fit your crimp tool. I just use needle-nose pliers for this.
Roadrunner
coyotes after you
Postby Roadrunner » Mon Jan 10, 2022 11:45 am
Excellent advice as always Lokiel!
MeepMeep
