Starter motor? Or ...?
greenMachine
Postby greenMachine » Tue Aug 31, 2021 12:52 pm
SE won't start. Battery has been on trickle charger, which shows all OK, battery showing 12.something volts on the multimeter. Car has been sitting for some couple/three months.
On the key, everything lights up, but turning to start the lights go dim, and the starter goes urg urg, not vroom ... if you know what I mean. Lights on high beam, horn works pretty good, maybe not 100% only 90% (closest I can come to a load test). The starter has not exhibited any symptoms to date.
I guess the thing to do is pull the battery and get it load tested at a local workshop, which is my next step.
In the meantime, any wisdom out there?
:mrgreen:
The American
Re: Starter motor? Or ...?
Postby The American » Tue Aug 31, 2021 1:14 pm
Can you test with some jumper leads to see if that provides enough to get it moving?
Postby bruce » Tue Aug 31, 2021 1:35 pm
Nahh, the car's boogered. I'll take it off your hands for a lazy tenner, will send tow truck.
(I remember when our paint-fumed, bird loving forum member said he'd give his SE away if he repainted it again. I took him up on that offer when he re-did the paint and he got mighty upset. I think he might have gone and choked a budgie!)
greenMachine
Postby greenMachine » Wed Sep 01, 2021 11:44 am
bruce wrote:Nahh, the car's boogered. I'll take it off your hands for a lazy tenner, will send tow truck.
Bruce, you need the tenner more than I do, but I appreciate your generousity!
The American wrote:Can you test with some jumper leads to see if that provides enough to get it moving?
That had been the plan, but the jumper leads had gone walkabout. I took it down to be load tested yesterday, and the result was poor but could have been a problem with the tester.
However this morning the jumper leads have been found, so I need to get the battery back in the car and hook up another battery and give that a go. That should - hopefully - point to the culprit.
:mrgreen:
greenMachine
It's the battery stupid!
Postby greenMachine » Wed Sep 01, 2021 9:18 pm
Battery is cactus. Started with the aid of a set of jumper leads, ran it for a while after disconnecting the jumpers, shut down and then restarted ok. I'll try it in the morning, I think that will be a bit too much to ask, but you never know ...
I've been researching batteries, looking for something a bit bigger than the PC680 as maybe I am asking a bit too much of it, at 170CCA. Looked at the Fullriver HC20, it has more grunt (220 vs 170 CCA) but physically virtually the same size. The HC 35 gets a wrap in one of the battery threads here, lots of CCAs there!
In the course of that research I have seen a reference to not leaving the AGM batteries on a trickle charger for extended periods*. Mine was on for around 3 months, maybe a bit less, and while the battery seemed healthy enough when I last started the car. after being on the charger for that period the battery now seems due for replacement. Coincidence? Has anyone else seen a similar warning for AGMs, or experienced something similar? Charger is a C-Tech, cost me $70+, has a 'maintenance' function.
:mrgreen:
* "it performs poorly when repeatedly taken down to deep depths of discharge or if they are placed on a continuous trickle charge,"
rascal
Re: It's the battery stupid!
Postby rascal » Thu Sep 02, 2021 9:47 am
greenMachine wrote:In the course of that research I have seen a reference to not leaving the AGM batteries on a trickle charger for extended periods*. Mine was on for around 3 months, maybe a bit less, and while the battery seemed healthy enough when I last started the car. after being on the charger for that period the battery now seems due for replacement. Coincidence? Has anyone else seen a similar warning for AGMs, or experienced something similar? Charger is a C-Tech, cost me $70+, has a 'maintenance' function.
:mrgreen:
I fitted a motorcycle battery to mine at end of 2014.
this one. https://www.batteryworld.com.au/YTZ14SY ... le-Battery
230CCA, 11.2Ahr, 3.9kg AGM style.
I wouldn't use it for a daily driver as its a little small for the job but worked perfectly fine to start the car 15 or 20 times in a day as per a normal track day usage.
Since it was small, it needed to be fully charged to start the car from cold when the car took a few goes to fire, (and one 1deg Wakefield morning it didnt make it and I had to jump it) so I made sure it ALWAYS was on the trickle charger between events. ie as soon as I got home from track and unloaded car it was on the trickle, until the morning I left for the next one.
So it would be on the charger 99% of its life, and sometimes 3 months straight. Never had an issue with it losing or not holding charge and still works perfectly now nearly 7 years on. (and I've even flattened it prob a handful of times over that duration due to various reasons)
My trickle charger is also a CTek (MXS 5.0) that has an AGM function on it, which I use. Not sure if this make the difference or not, but the proof appears to be in the pudding..
greenMachine
It lives!
Postby greenMachine » Thu Sep 02, 2021 10:23 am
Thanks rascal, that's interesting.
I started the car again this morning, no jumper, it didn't sound all that strong but started after a couple/three goes - so the battery still has some life it seems. I've left it running for 10 or 15 minutes at 2-3k rpm to give the battery a shot in the arm, and I'll try it again tomorrow.
I think my charger is the same model, it has an AGM function which as I recall is on as per the indicator light. In which case maybe the issue I have experienced is not related to trickle charging. At the moment the charger is not connected, everything is just sitting there and now I will put things back in place properly, reconnect the charger and play with it a bit.
I hear you about racing car cold starts. My old racecar used to be a b@st@rd to start at Wakefield, aggravated by living in the open here at home with overnights down to -7* or so in winter. Initially it ran an even smaller Odessy but I upgraded to the PC680 after a similar experience at Wakefield. The SE now lives in a garage, so the battery will have an easier life - having lasted several years living in the open, and working OK, 170CCA seems adequate but the crunch comes when staying away in cold weather and no access to charging.
I think a new battery is in my future, but maybe I have a little more thinking and searching time that I imagined last night.
:mrgreen:
RS2000
Postby RS2000 » Thu Sep 02, 2021 11:09 am
I've had a Fullriver HC20 in my race NB8A for 2.5 years. Not a problem with it, & sometimes the car doesn't get started for weeks & weeks.
Of course the ignition isolation switch is turned to off. I only charge the day before an event, with a Ctek 4.0 on AGM setting.
rascal
Postby rascal » Thu Sep 02, 2021 11:30 am
Also GM, regarding your existing battery, the Ctek has a Recondition function which might be worth trying as it actually works quite well.
I (thought I) killed my battery in my tow car a few years ago, so bought a new one.
Thought I'd give the recond function a go on the old battery given nothing to lose, and to my surprise it worked.
Before battery was showing 8v, which is dead as a dodo, and normally anything that low wont recover.
I put the recond on and left it for a few days, Then took it off left it for a day and then did recond again for another few days, and afterwards it came back to life. holding 12.6v!, and started the car several times no problems.
I ended up moving it to the trailer to run the internal lights, and was still running fine there a few years later without issue when I sold the trailer last month.
CrazyRacer
Postby CrazyRacer » Fri Sep 03, 2021 3:47 pm
I've fitted a SSB Lithium PowerSports battery to the race car. Weighs about 1kg and seems to hold charge when not in use much better than a regular battery.
It hasn't been used in anger yet, but has done plenty of cranking while I've been sorting out the new ECU. If it was for a road car I'd get one a little bigger though.
Make sure you stay away from SuperCharge batteries. I've had 3 different models fail in 3 different cars. Only saving grace is their long warranty which meant all of them were replaced for free.
greenMachine
Postby greenMachine » Sat Sep 04, 2021 9:22 am
Thanks guys. It started unaided again yesterday, still a little down on grunt I think. I've downloaded the C-tek manual and I'll reconnect it today. Doing a 'recondition' seems like a good idea, I might start out with that.
CR, if the Odyssy needs replacing, it will be with an AGM Fullriver, probably the HC20 because that has a bit more grunt than the PC680, and it will easily fit the PC680 mount, but that is not imminent - probably autumn next year.
:mrgreen:
greenMachine
Postby greenMachine » Mon Oct 24, 2022 10:22 pm
Finally replaced the Odyssy with a HC20 Fullriver, direct replacement for the PC680, just on $200.
The battery place told me that the AGM batteries don't like to be run flat, and that happened at least one to mine. Let's see how this one goes.
:mrgreen:
StillIC
Postby StillIC » Wed Oct 26, 2022 8:35 pm
No lead acid battery likes to be run flat.
I went to a Lithiumax lithium-ion battery, some years ago (2017?), and for $400 and something dollars I expect it will last more than twice as long as a lead acid and saves 9.5 kg to boot (11 kg to 1.5 kg)!
