NA 1.6 Headlight retractor relay location
Purfler
Postby Purfler » Wed May 05, 2021 11:44 am
Hi, Sorry for the stupid question, but I'm looking for the headlight retractor relay location in my 93 NA 1.6. The Rod's guide talks about a relay in the engine bay, but removing that makes no difference (ie the still work).
I'm trying to track a new intermittent problem with the light stalk. The retractor button operates the retractors fine.
Thanks in advance.
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
Re: NA 1.6 Headlight retractor relay location
Postby bruce » Wed May 05, 2021 1:33 pm
Not a stupid question.
Not sure regards the relay spot, but I do know that the light stalks do wear out and cause such problems.
Purfler
Postby Purfler » Wed May 05, 2021 4:16 pm
Thanks Bruce. I wondered if it could be the switch. There's a fair bit of stuff on the web about relay problems, but I'll test everything - once I find teh damn relay. BTW the relays cost silly amounts of money for reasons not very apparent to me.
Tim
Postby 93_Clubman » Thu May 06, 2021 10:53 am
Tim, assuming an ADM NA, the Imasen LA10 relay should be under the dash on the driver side. As Bruce mentioned the issue is usually with the light stalk & collar mechanism - from memory Rolley or someone else on here posted a fix for it, but depending on how bad it is, a lot of owners just live with it. Here's some recent posts on the issue:
viewtopic.php?f=55&t=75948&hilit=collar
viewtopic.php?f=55&t=74659
A number of owners just replace the relay with a used one from a wrecker (doesn't need to be an MX5 wrecker) or ebay.
Purfler
Postby Purfler » Thu May 06, 2021 11:55 am
Thanks very much for the terrific information. I'll investigate further and see where the issue lies. Of course, it all works perfectly today.
Tim
