Hi i just purchased a 1992 Eunos Roadster 1.6L, the issue with it is it only starts up after around 4 or 5 attempts as the immobiliser cuts the engine out on the other tries, is it an immobiliser issue and is there an easy way to just remove the immobiliser to run it as im only using it over the summer. Cheers
Sent from my SM-G973F using Tapatalk
Eunos 1.6 Immobiliser Issue
- Learner Driver
- bruce
- Vehicle: NA8 - Turbo
Re: Eunos 1.6 Immobiliser Issue
It could be anything by the way you describe it.
NAs only got immobs/alarms fitted as aftermarket. If you genuinely think it is that, take it to an auto elec to remove it.
viragmakwana wrote:is there an easy way to just remove the immobiliser
There's usually no easy way to remove them, hence Bruce's auto elec suggestion.
- Ross
If you're carefull and pay attention to tracing one wire at a time you can DIY the removal.
I did mine after the immobiliser started to pay up.
It took a while and you will be working under the dash, so typically upside down, trying to solder thin, old wires - be prepared to drip hot solder onto yourself.
So much fun
But mine starts first time, every time now
So much fun
Ross
1990 BRG V-Special, NB Koni sport with King springs, MS-03's
Ross
For OP, if you decide not to take it auto elec & diy, then remove the driver seat so that you can lay on your back on the floor with you feet up on the rear parcel shelf to access under the dash.
93_Clubman wrote:you will be working under the dash, so typically upside down
Plus padding, lots of light, good clear eye protection, BMI<23
Just saw my GP this afternoon. He has done his knee in rewiring under the dash of his TR4, twisted it extricating himself
