Our NA6 came to us with a COP conversion already done, as an artefact of the previous Adaptronic & turbo install (but is now running NA and standard ECU).
Here's where it gets messy: the standard coils are still fitted and connected. This has lead to the coils arcing over and burning the ends of the coils, and ticking like a dead lifter.
If I disconnect the standard coil packs, the car stalls after a couple of seconds (I assume something to do with the ECU not seeing an ignition pulse).
So... Why shouldn't I just replace the stock coil packs and plug leads, and ditch the COPS?
Or is there an easy way to disconnect the stock coil packs that doesn't stop the car?
Cheers!
Coil on plug.
- NitroDann
Re: Coil on plug.
I don't know how your system works but an auto electrician will be able to figure it out in 5 minutes and get it all working in an hour or so.
Re: Coil on plug.
You would be best to remove the COP conversion and go back to standard coils/leads.
The COP setup would require you to be able to adjust dwell setting down often to 2.5ms, not reasonably possible with the standard computer. I'd say it has been jerry-rigged to work after adaptronic was removed but will need to be addressed ASAP. Consult shop manuals or haynes manuals to get an idea of the oem setup and inspect your wiring for modifications before taking along to an auto sparky.
Na6 wiring is beautiful in it's simplicity, I can share diagrams from the 9/89 edition shop manual to help if needed.
Re: Coil on plug.
The standard ignition system sends a feedback signal to the ECU to verify coil firing. Unplugging the standard coils will interrupt that, so that is probably why the engine then stalls. (The only easy way around that is to use an aftermarket ECU…).
As you suggest: best to remove the COP ignition system and put everything back to standard.
One caveat is that the standard coils have been running for a while with no leads and plugs attached. This generates higher than normal voltages in the coils (you can hear the arcing) and might have damaged them, so you might have to replace them for reliability.
- StanTheMan
Re: Coil on plug.
Let us know if you want to sell the Cop system. I might be interested
My standard system packed it in today. Ive started the research on wiring up a COP system.
Sent from my SM-G935F using Tapatalk
Re: Coil on plug.
StanTheMan wrote:Ive started the research on wiring up a COP system.
You've probably already found this, but if not it's very comprehensive & also applies if running MS:
http://mx5cartalk.com/forum/viewtopic.php?f=77&t=67222
There were also a couple of other good ones on here by tbro
http://mx5cartalk.com/forum/viewtopic.php?f=77&t=44754
& green_comet (was on Youtube).
Users browsing this forum: No registered users and 37 guests
