Does anyone know the 4 digit generic radio code for the SE NB? Mine has err displayed on the screen and while I can get back to the four dashes that’s as far as I’ve got.
I’ve tried combinations on line but they are for either UK or European. Also tried the last four digits of the vin with no success.
Radio code se nb
Radio code se nb
NB SE, NA 1.8.
Re: Radio code se nb
See half way down this page: https://www.miata.net/faq/faq3.html
Or see this: https://www.miata.net/faq/radiosec.html
If that doesn't work, this might contain info to assist: https://www.miata.net/garage/nbaudio/index.html
Thanks mate. I tried all of those but with no success. Have the right combination to get to the four dashes but not then the four digits.
NB SE, NA 1.8.
Appears to be alternatives depending on domestic market & model:
1414
or
0532
or
4989
or
3511
1414
or
0532
or
4989
or
3511
Thanks for that - there was a few numbers I hadn’t tried but no luck so far. I presume I just leave the first button alone to make a zero. After punching in the numbers I then hit auto and button 6. Tried both together and seperate to no avail.
Looks like I’ll have to take it to Mazda...
NB SE, NA 1.8.
Couple of clear step by step write-ups:
https://www.mazdaforum.com/forum/mazda- ... ode-16552/
https://www.mx5oc.co.uk/forum/yaf_posts ... evada.aspx
More codes: http://www.mx5nutz.com/forum/index.php?showtopic=255393
