Speaker troubles
Rose_O78
Speaker troubles
Postby Rose_O78 » Fri Mar 09, 2018 7:15 pm
I have an original bose system and have an issue with my speakers.
When I first take the car out of the garage the speakers make a vibrating noise so bad that I have to turn the stereo off.
Sit her in the sun for a bit and the speakers are sweet!
Sux on overcast days driving without tunes
I've checked and the cones look good.
Any ideas ?!?
Re: Speaker troubles
Postby KevGoat » Fri Mar 09, 2018 7:28 pm
Intake & exhaust ....
Rose_O78
Postby Rose_O78 » Fri Mar 09, 2018 7:34 pm
KevGoat wrote:Intake & exhaust ....
Postby KevGoat » Fri Mar 09, 2018 9:31 pm
Rose_O78 wrote::?
:mrgreen: ... you'll get use to us :lol: ... but top down with a decent intake & exhaust is the best music :wink:
But yeah, no genuine idea what's happening with your speakers. Usual stuff - check all the wiring inside the door is held in place and not rattling against anything. You'd have taken the speakers out to look at the cones, so assume all the screws etc would be back in tight. The cones could have got wet at some stage and softened - they would still look OK, but by sitting in the warmth of the sun, they would "stiffen" and possibly stop rattling. Unless someone with more knowledge has some good ideas, it sounds like there's probably no way round fitting new speakers.
Rose_O78
Postby Rose_O78 » Sat Mar 10, 2018 9:53 am
KevGoat wrote:
Rose_O78 wrote::?
Haha yeah new exhaust is on the cards
New speakers it is then! Suggestions on a decent brand? Don't want cheap crap in my baby lol
Postby KevGoat » Sat Mar 10, 2018 10:20 am
I'm certainly no audiophile ... I've always been happy with Pioneer for head units and speakers, but I reckon the best thing is to go in and listen to them.
Edit: ... an alternative is if you like the Bose ones in there now (when their not rattling), see if anyone on here has some they've removed they want to sell ...
Also just thinking back I think there was an issue with replacing the speakers on the Bose system ... maybe someone who's done it could answer that?
Rose_O78
Postby Rose_O78 » Sat Mar 10, 2018 10:33 am
KevGoat wrote:I'm certainly no audiophile ... I've always been happy with Pioneer for head units and speakers, but I reckon the best thing is to go in and listen to them.
Thanks heaps! I might go talk to an audio place today and see what they say.
Otherwise there is a guy on here I bought a second hand stereo from....I'll track him down
Postby KevGoat » Sat Mar 10, 2018 11:18 am
Ah ... found that issue I had in mind ...
Quote from Miata.net ... "Bose speakers have a .5 ohm impedance. They are run from the special Bose amp unit. Some aftermarket head units seem to be able to be run into the Bose amp successfully, but there are also after market line matching amps to go from a standard HU to the .5 ohm speakers (check Crutchfield for examples); Clearwater makes .5 ohm speakers for the Bose set up which sound light years better than stock Bose speakers....."
Reading that I'm guessing normal 4ohm speakers can't be used with the Bose head unit.
Rose_O78
Postby Rose_O78 » Sat Mar 10, 2018 4:42 pm
KevGoat wrote:Ah ... found that issue I had in mind ...
Cheers for that. Food for thought...
Postby Regie » Fri Mar 16, 2018 8:12 am
I had the same problem recently with my car. the speakers would make a cracking noise especially going over bumps. didn't happen all the time though.
it was the big plug into the back of the headhunt not being fully plugged in. check that first, could be a simple fix!
Rose_O78
Postby Rose_O78 » Fri Mar 16, 2018 12:42 pm
Regie wrote:I had the same problem recently with my car. the speakers would make a cracking noise especially going over bumps. didn't happen all the time though.
Sweet shall Do!
Users browsing this forum: No registered users and 43 guests
