Buzzer NB
Posted: Sun Mar 05, 2017 7:29 pm
by roshmx5
Hi is there a way to stop buzzer warning for key indignation door open, but leave buzzer to warn if you have left your lights on. Own a NB.
Re: Buzzer NB
Posted: Sun Mar 05, 2017 10:58 pm
by Locutus
Trace the sound to the buzzer under the driver's kick panel and unplug it.
Re: Buzzer NB
Posted: Sun Mar 05, 2017 11:49 pm
by Rolley
I'm pretty sure it's the same as the 323/Laser.
There is a small two wire plug on the ignition lock cylinder that can be unplugged to silence it.
I can't 100% remember if it just stopped just the door buzzer or if it killed the headlight warning as well.
Remove the trim ring from the ignition lock, remove the 4 screws that hold the clamshell cover from the steering column (remember which hole the machine threaded screw came out of) Split the clamshell and remove just the lower section. You will then be able to see all of the harnesses.
Disconnect the two wire connector and test before reassembling. It is a white small connector, usually wrapped with a sheet of adhesive backed 3mm foam.
Re: Buzzer NB
Posted: Mon Mar 06, 2017 12:29 am
by Rolley
Re: Buzzer NB
Posted: Mon Mar 06, 2017 8:18 am
by ManiacLachy
It helps to pull the driver's seat out while you're looking for it. The 2 1/2 minutes it takes you to undo the 4 bolts and pull the set will save you a lot of agony and allow easy access under the steering column ;)
Re: Buzzer NB
Posted: Mon Mar 06, 2017 8:44 am
by Roadrunner
Crazy simple and the best mod you'll ever do.
Take off the steering wheel column trim.
- 2 screws on the large flat panel that you always hit your knees on.
- 3screws on the bottom side of the clam around the steering column (remember which screws came from where. one is slightly different)
- The clam clips into itself, pry the top and bottom parts apart and remove.
On the passenger side of the column theres a small white plug (next to a big yellow plug - this is the airbag, don't unplug that)
Put your keys in the ignition and unplug white connector. Rejoice in the silence.
The buzzer will still sound if you leave your headlights on.To take it one step further, reach under the seat and disconnect the plug going to the seat belt stalk.
No more seat belt beeping either!!
Re: Buzzer NB
Posted: Mon Mar 06, 2017 10:34 am
by roshmx5
Thank you so much everyone much appreciated
Re: Buzzer NB
Posted: Tue Mar 07, 2017 11:34 am
by roshmx5
I can't find the connector I have two green wires coming out of ignition and two white wires. Have disconnected them goth still buzzing.
Re: Buzzer NB
Posted: Tue Mar 07, 2017 11:50 am
by ManiacLachy
I can't describe which one it was, but I just kept unplugging & re-plugging connectors until it turned off, then I taped it up out of the way.
I'll see if I can spot it for you at lunch time if you're still struggling.
Re: Buzzer NB
Posted: Tue Mar 07, 2017 3:03 pm
by roshmx5
Thanks so much I did the same unplugged what I could see, I own a 2002 SP. still was beeping.
Re: Buzzer NB
Posted: Tue Mar 07, 2017 3:17 pm
by Roadrunner
Sitting in the drivers seat, imagine the ignition is on the left side. Where you'd put the key in on the left side is where the plug is.
I'll try to find a photo
Re: Buzzer NB
Posted: Tue Mar 07, 2017 3:52 pm
by roshmx5
Thanks so much found it
Green wire plug. And lights still beep.
Thanks everyone am so happy, god bless you all.
