(BNE)NA8 CAS new pigtail and connector needed
chefie
Postby chefie » Thu Dec 29, 2016 5:00 pm
Ive got a NA8 clubman. A recent purchase that needs some TLC, its not a DD and no urgency but working through the electrical/Mechanical issues before a respray, she has been running really rough when cold missing etc, the car drives great when hot. yesterday she struggled to hold idle and was ok when hot.
Comp test is good at all 4 pots 180 psi and no HLA noise,
today started and ran for 2 minutes cut out and wouldnt start again, i went looking for spark fuel etc
I found the SGC wire on the CAS broken at the base of the connector. Does anyone have a spare i can purchase in Brisbane or advise where i can make buy a pigtail made up with connector? does jaycar have the 4 pin socket connector, also the wires to the cas have been repaired previously so i want to fix it properly to eliminate as a future issue when sorting the idle problem
i am sure this will be one of many electrical component issues i will be chasing to diagnosing the start and idle issue.
cheers
98 NB8A Grace Green
LS 66.17,QR Club 69.27, QRSpr 63.58 SOLD
01 NB8B Grace Green
LS 64.66,QRNat 1.31.94,QR Club 65.17 QRSpr 62.36
93 NA8 Clubman
chefie
Re: (BNE)NA8 CAS new pigtail and connector needed
Postby chefie » Thu Dec 29, 2016 5:20 pm
98 NB8A Grace Green
01 NB8B Grace Green
93 NA8 Clubman
Postby Magpie » Thu Dec 29, 2016 7:39 pm
Cannot see the photos, is the CAS on the back of the engine or on the front?
chefie
Postby chefie » Thu Dec 29, 2016 9:34 pm
the CAS is at the back of the head on Ex side
it looks like a std 4 pin denso plug,
wtf with posting images, set up a flickr account and pasted the url in the IMG link ????
ill try a auto elec tomorrow if any are open
98 NB8A Grace Green
01 NB8B Grace Green
93 NA8 Clubman
Postby Magpie » Fri Dec 30, 2016 7:24 am
If you can send me a photo I can check on the shell for the plug.
chefie
Postby chefie » Fri Dec 30, 2016 2:47 pm
Big thank you to Blackleaf for helping out
and for helping with posting images
98 NB8A Grace Green
01 NB8B Grace Green
93 NA8 Clubman
BlackLeaf
Postby BlackLeaf » Fri Dec 30, 2016 8:09 pm
No problemo.
BlackLeaf
R.I.P. 90 Mariner Blue, 12/12/90 - 10/12/15
#321 89 Classic Red, 04/12/15 ->
3gress
Postby 3gress » Fri Dec 30, 2016 11:41 pm
Hi mate, i just ordered a heap of new plugs from ballenger motorsports www.bmotorsports.com.
The cas plug was included in order and is part no.#CONN-75802 for the plug and terminals.
I think they offer a pigtail version too. The item name is '4 way plug kit for japenese sensors' and was cheap and quick to get to me. Hope it helps, alternately i have a plug from an old loom i could chop off and send to you. Cheers fella.
3gress
Postby 3gress » Sat Dec 31, 2016 2:11 am
chefie
Postby chefie » Sat Dec 31, 2016 11:36 am
Thanks 3 gress
all sorted thanks to Blackleaf, now chasing a ICV solenoid issue or a clt issue on the idle
Thanks for the offer and the links
cheers
98 NB8A Grace Green
01 NB8B Grace Green
93 NA8 Clubman
Postby 93_Clubman » Sat Dec 31, 2016 4:00 pm
If it was an NA6 with rough cold idle, I'd immediately say CTS (green plastic top), but NA8 seems less prone to U/S CTS: Image
chefie
Postby chefie » Sat Dec 31, 2016 6:28 pm
found this when looking for the cold idle issue
https://www.miata.net/garage/isc.html
very detailed whilst for a NA6 is still relevant,
93 clubman do you know if the 92 NA6 ISCV is the sames as the 93 NA8, i am still looking for the spec differences
98 NB8A Grace Green
01 NB8B Grace Green
93 NA8 Clubman
Postby 93_Clubman » Sun Jan 01, 2017 10:09 am
They're different - NA8 BAC valve combines IAC valve & air valve, which in NA6 is split between bottom of throttle body (ISCV) & bottom of intake manifold (air valve). See pages 5:2, 5:4 & 5:11 in following re NA8 BAC valve (opens on page 5:11 BAC testing):
https://books.google.com.au/books?id=8e ... ve&f=false
Btw, check for intake system leak - some years ago a forumite had a cold idle issue that went away when warmed up. Turned out to be an intake system leak which sealed itself as it warmed up. Unfortunately can't find the thread anymore, but it took a few pages to solve.
chefie
Postby chefie » Sun Apr 09, 2017 6:46 pm
Quick update
The Clubman is running, :D
Broken CAS Pigtail Yell Blu signal broken at the base, Thanks Blackleaf
Shorted white CAS signal wire under brake booster, repaired, also took out the O2 red signal wire with the gnd cover. looked like spilt brake fluid over time broke down the wires to a short
Chased the ecu error codes for IAT, MAF and TPS as they were all on the same Blk Blu GND found a broken Gnd wire
Grabbed a 2nd hand MAF and ECU from Red Bullet, Whom has been a great help thank you.
Purchased a TPS to fix the error codes
Replaced the water ecu temp sensor and CAS oring whilst i was back there
removed the aftermarket alarm system and repaired the ignition loom that was butchered
Checked the entire Loom resistance yesterday and installed Reb bullet ecu, runs like a new one and everything works
Diagnosis of an electrical is sooo difficult you need patience some knowledge a lots of forum help saved, this saved me from towing her to a wreckers
98 NB8A Grace Green
01 NB8B Grace Green
93 NA8 Clubman
