A NA with Headlights that turn on and off but do not go Up or Down is bothering me currently.
I have no idea when they last worked or if anything has been done to make this an issue but i have pulled what i believe to be the Retractor Relay from under the Steering wheel.
I pulled the Relay Casing apart and i noticed a bad section on the PCB.
Could this be the issue??
Electrics are not my strong suit
Could i just join these with a piece of wire and solder to test??
Would anyone also know the Pin Allocation to test with a multimeter? ?
Any help much appreciated.
