Does anyone know where this is?
My black sp has broken down, the engine shut down while i was driving around a roundabout the other day. Have found out there is no signal going to the fuel pump, ive checked and tested the fuel pump and even changed it for good measure. Looking under the driver dash for this thing and cant tell the difference with all the wires and different plugs!!
Does anyone know if the setup will differ as it is an sp? It looks different from the pics that ive seen but i also have a turbo timer wired in under there which might also be why.
SP fuel pump relay
