Evaporator Sensor Fault?
Posted: Mon Dec 21, 2015 11:45 am
Hi All,
Just wondering on your thoughts on this. In the middle of summer it hasn't been pleasant with the AC switching off suddenly!
I have narrowed it down to the evaporator temp sensor, photo below. The probe penetrates the evaporator housing, I have read that when the temp inside falls below X degrees the sensor will trip and stop the AC compressor, when the temperature warms up again the sensor will "reset" and the compressor will run again. This is normal operation.
My problem is that the sensor does not "RESET", so the AC never comes back on after tripping the first time. Turning the AC switch on/off doesn't help either. The only remedy i have found is to reach behind the glove box and "jiggle" any one of the two terminal connections on the sensor. As soon as i do that the compressor runs again until the next trip.
Is there a way to test the sensor (i have a multimeter)? Is there an easy way to replace or will the entire evaporator unit need to be removed and opened? This appears only to happen on the hottest days, does the heat have an affect on the sensor (which is outside of the evaporator) resetting? The system has plenty of gas, no leaks.
Thanks.
Thanks.
