NA main fuse box label
LiteIsRite
Postby LiteIsRite » Wed Dec 09, 2015 8:54 am
Being a bit of a neat freak, I started looking at options for replacing the damaged label on the fuse box in my (NA) engine bay...
In the end, I decided to just make my own. I drew it up in Inkscape, printed, cut out, & laminated it. Then, using very thin double-sided tape of the sort used by scrapbookers :roll: I stuck it on...
Here's a side-by-side comparison, after the fact, where I realised Mazda had used gray rather than white for the graphics - but I'm happy enough with the result. The new one is smaller to allow a border for the lamination seal.
If you want to do your own, the graphic is attached (free for personal use). Just print it to an A4 sheet and it will be the right size.
Main_Fuse_Label.pdf
"Cherry" - Classic Red 1990 NA6 :NA6: [sold]
Re: NA main fuse box label
Postby 93_Clubman » Wed Dec 09, 2015 2:34 pm
That's a good repro - a while back someone was looking to replace one of their NA fuse box labels, so tks for the attachment.
ianoz
Postby ianoz » Thu Jan 07, 2016 11:14 am
Thanks for that!
Missed with the pressure wash when I first got the car and chewed up a perfect label :roll: It's annoyed me ever since - even though the rest of the car is a bit rough...
NA6 '89 red, NB8B '01 silver
speed
Postby speed » Sat Jan 09, 2016 6:19 pm
Awesome!
I would have been tempted to name the blank one "missiles " or "ejector seat" but what you have done is perfect.
Thankyou for sharing.
LiteIsRite
Postby LiteIsRite » Sun Jan 10, 2016 6:36 pm
Like your thinking, speed. Like it so much, in fact, I've made a revised version (attached) that I may fit to my car :wink:
