Ok so i have a 1/8 npt vdo sensor and a asi 1/8 nptf hose adapter.
Will the npt to nptf require sealant and if so which is the safest to use as to not alter the temp readings from the sensor?
water temp sensor
- Vehicle: NB Roadster
water temp sensor
WINTON PB - 1:57.4000
Re: water temp sensor
Not sure if you need sealant, but frankly a little smear wont hurt.
No need to worry about the sealant being sensor safe with a water temp sensor, that only really applies to things like 02 sensors that can give weird readings with the fumes from the sealant.
Pretty much anything should work, as long as it can take the heat, and won't dissolve in water (i'm pretty sure all auto sealants are ok on both counts)
Also thread tape works fairly well. I find it less messy than sealants.
May be worth noting the sensor grounds through the adapter. So using any sealant will need to be carefully.
narita wrote:May be worth noting the sensor grounds through the adapter. So using any sealant will need to be carefully.
ohhhh.....
In that case use nothing.
- bartmanftw
But doesn't the housing sit between two coolant hoses? I'd use sealant and add a ground from the sensor housing the engine to get a good ground.
I've found with using sealant or thread tape that there must still be enough contact on the threads to earth it. I've always used some sort of sealant as I hate leaks and never had a problem with earthing.
- zossy1
madjak wrote:I've found with using sealant or thread tape that there must still be enough contact on the threads to earth it. I've always used some sort of sealant as I hate leaks and never had a problem with earthing.
+1
You should use an electrically isolating but heat conducting sealant on all exposed faces of the sensor. Otherwise the sensor will ground through the coolant and promote engine destroying electrolysis. I find hysol to give good results. http://www.loctite.com.au/3320_AUE_HTML ... 2643214337
The high strength epoxy is strong enough to resist the erosion fretting that can effect the sensor due to the high water flows. Smearing a bit of the left over on the joins between radiator hosing and sensor adapter will also prevent crevice corrosion on the adapter.
I've almost missed your trolling Narita. I see your stilling working on your subtlety. It's getting pretty good, this one was almost a logic puzzle.
Thanks.
Not trolling this time. The hose adapter has a seperate thread for the grounding wire. So the threads of the sensor need to be able to ground through the sensor.
It the sensor truely needs to be grounded it can't be installed in a radiator hose with out providing a cable from the adapter to the body. Which isn't impossible just strongly recommended.
sailaholic wrote:It the sensor truely needs to be grounded it can't be installed in a radiator hose with out providing a cable from the adapter to the body. Which isn't impossible just strongly recommended.
narita wrote:The hose adapter has a seperate thread for the grounding wire.
Hmm I read that differently. Not quite sure how now.
